It is currently Fri Jul 18, 2025 6:50 pm
 Post subject: Clutch Slave
PostPosted: Tue Jun 10, 2008 1:45 pm
My clutch is slipping - but the clutch seems to be fine
However the clutch slave return position - ie the position the slave returns to after the clutch pedal is released seems too extended. ( I know what I mean). The spring is retracting the slave however it reaches hyraulic resitance and stops. If turn the stop bolt and disconnect the slave there is a lot movement left in the arm.
The slave is newish - 12 months old - is it adjustable?
Is it a case of resetting the slave pin by open the valve and readjusting the pin default position or am I barking up the wrong wooden leg?
 Post subject: Re: Clutch Slave
PostPosted: Tue Jun 10, 2008 4:30 pm
I usually work my slaves until they die..
PostPosted: Tue Jun 10, 2008 4:35 pm
The slave itself needs no adjustment.
You mentioned turning the stop bolt. If it is hitting that, then it is not hydraulic resistance, it's the stop that needs adjustment.
PostPosted: Tue Jun 10, 2008 4:38 pm
Nup not hitting the stop bolt.
PostPosted: Tue Jun 10, 2008 5:16 pm
Is the clutch arm bent or straight ? They are meant to be straight but people bend them when the hydraulics get tired or the pivot wears . I'm guessing your's might be bent so far that it won't allow the arm to reach the stop because the pin is bottoming out in the slave cylinder .
PostPosted: Tue Jun 10, 2008 5:32 pm
Some people Image have been known to extend the clutch slave pin by welding a bit onto it to take up the slack in a worn clutch arm assembly. Could be bottoming out inside the slave cylinder.
PostPosted: Tue Jun 10, 2008 5:51 pm
But if the arm and gubbins arent worn and the PO had welded an extension onto the slave pin that was used on the previous rooted setup - then would ut cause my symptoms ? The pin does have about a bit welded to the end
PostPosted: Tue Jun 10, 2008 5:54 pm
Sounds like it.
Got an unmolested pin? Or just grind yours back to original.
(you have a welder so you can always make it longer again)
PostPosted: Tue Jun 10, 2008 6:03 pm
I'll attack it with the grinder tomorrow - thanks
PostPosted: Tue Jun 10, 2008 7:06 pm
It will be the clutch hose. :wink: When they die they work as an effective one way valve.
PostPosted: Tue Jun 10, 2008 7:29 pm
Slow-Po
Sorry Cush, but that "humour" really had a touch of the Gadgets to it. :P :D
PostPosted: Tue Jun 10, 2008 7:30 pm
new :roll: thats what I like about the Moke everything is new but it still behaves like its 30 yo
Users browsing this forum: Bing [Bot] and 103 guests
