It is currently Sun Jul 06, 2025 7:28 am
 Post subject: Diff selection help?
PostPosted: Thu Jul 24, 2008 2:30 pm
I have orderd a new set of straight cut gear from the UK (Three months ago :evil: :evil: and they are still on back order) I have been told that first gear is very tall so it may be a little hard to get off the line.
If any one runs straight cuts on the road what diff are you running to compensate for the tall first gear?
PostPosted: Thu Jul 24, 2008 2:37 pm
I ran a factory sc/cr 3 synchro remote box in my Cooper S for years on the road, along with a 649, Browriggs and 45 Weber. I always used the 3.44:1 diff with no problems, and that was coping daily with Melbourne traffic. Gives you a great take off range before you need to change into second.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Thu Jul 24, 2008 4:56 pm
I have a spread sheet I put together to illustrate gear ratios with diff ratios etc. pm me your email and I'll send it too you...
PostPosted: Thu Jul 24, 2008 4:58 pm
I have a 3.44:1 and it's a biatch to drive on the street in traffic, not that I do that anymore...
Daniel
PostPosted: Thu Jul 24, 2008 9:52 pm
You can try this web site....
Has an online calculator just put in the various details (geraing, wheel size, diff ) and it'll show the data...
http://www.guess-works.com/Gearbox/Technical/ratio.htm
PostPosted: Sat Jul 26, 2008 2:47 pm
Mine is similar to that but I grabbed a dyno plot to show torque versus speed and the overlap in each gear :D
It's not very accurate because each engine is different but its actually really interesting to mess around with...
PostPosted: Sat Jul 26, 2008 4:36 pm
Hi,
We ran a 3.4 diff in Targa one year and a 3.7 the next with a four syncro SC gearbox. The 3.7 was my choice, the 3.4 is too tall and makes hill starts a killer expecially on really hot engines.
I know the English tend to run really low diffs...I don't think this suits our roads as well - mind you I am not an expert!
Rich
PostPosted: Sat Jul 26, 2008 9:10 pm
I just had a close look at my 3.44 diff pinion gear shaged. I think 3.7 would best suit what i want to use the car for thanks for your input.
Cheers Tony
