It is currently Fri Jul 04, 2025 6:36 am
PostPosted: Tue Aug 12, 2008 9:19 pm
This is how the doc did it on mine.
The brass adapters came from Pirtek, the pipe behind the PCV valve is actually a hydro pipe so don't let that confuse you. Otherwise it just goes straight into the manifold.
Ps Graham Russell does not recommend the balance tube effect between the ports on the manifold. There's probably not much he and DrMini don't agree on, but that's one of them.
PostPosted: Tue Aug 12, 2008 9:29 pm
Mk2 S with Police Pack twin HS4s didn't use that valve, the sidecover breather ran to the vac ports on the side of each carby instead.
did the breather hose go to just one carb or was it teed to both carbs ? I spose it had a different oil cap too
PostPosted: Tue Aug 12, 2008 10:13 pm
i assume the pcv valve allows air out of the engine but not vaccum from the inlet into the crankcase?
the vented cap doesnt work on mine, it spits oil out of it. I think it might be due to the boost.
i want to pipe the catch can back into the carb, but i'll need a pcv valve yea?
PostPosted: Tue Aug 12, 2008 10:53 pm
No PCV valve used if it goes to the carb, it goes onto the vacuum line at the side.
Like this- note I have since teed it to both carbs.
