It is currently Sat Jul 19, 2025 4:32 pm
 Post subject: Lifting bracket
PostPosted: Tue Feb 01, 2005 3:18 pm
Anyone have a diagram with measurments for an engine lift bracket?
David L
PostPosted: Tue Feb 01, 2005 3:32 pm
Wombat,
See the thread entitled "Best Method". This is exactly the question I asked before making one myself last week. I can measure mine and post tonight when I get home. It was just a bit of angle iron cut and drilled in the right spots, with a D bolt shackle welded on for the loop. A few other people posted with other options also.
Kevin.
PostPosted: Tue Feb 01, 2005 3:39 pm
That's what I was looking form and couldn't remember the thread :oops:
David L
PostPosted: Tue Feb 01, 2005 7:14 pm
I'm very much an amateur in the garage but this is the one I made last week with rough dimensions. If you have the Mini handy it's quite easy to drill the holes; if it doesn't quite fit, go up 0.5mm in drill size or file it a bit etc
As you will see the D shackle is welded offset towards the flywheel end (it mounts back to front on the head compared to the photo)
Now the engine's out, I might even sandblast and paint the bracket!
Hope this helps
Kevin.
PostPosted: Tue Feb 01, 2005 8:20 pm
Kevin, nice work, how is the balance of the motor with the dimensions of your bracket? Steve
PostPosted: Tue Feb 01, 2005 9:12 pm
Pretty good - the Doc gave me the heads up about offsetting it towards the flywheel 8) (I would have welded it centred!) :shock: . It was pretty much level coming out. I didn't have the radiator on but that wouldn't add too much weight to throw out the balance I wouldn't have thought. I made it out of scrap I had in the garage so if it didn't work, I could always start again.
Pretty simple to make. Cut some angle, drill it. Carve out the centre bit to clear #3 stud (counting from the radiator side), then weld a hook on (or get someone to if you don't have a welder).
In my case I got a D shackle and hacksawed the eyelets off before welding it on.
KB
PostPosted: Tue Feb 01, 2005 9:22 pm
Don't lose that...you will need t again.. :wink:
Just hang it where you can see it.....Sand blast it :wink: and a nice coat once you have finished with it..this time :!:
PostPosted: Tue Feb 01, 2005 9:52 pm
great pic KB....is that your own handy work?
PostPosted: Tue Feb 01, 2005 10:27 pm
Good pic Kevin - Now I have to get the welder back from my son in Rocky
David L
PostPosted: Tue Feb 01, 2005 10:29 pm
Don't be a cheapskate- just go buy another! 8) :lol:
PostPosted: Tue Feb 01, 2005 10:30 pm
Ya a nice MIG - :roll:
David L
PostPosted: Tue Feb 01, 2005 10:37 pm
Wombat,
Stick weld is stronger weld than a baby MIG one , on angle iron and round bar..! You don't want it to come off..
BTW Kevin I would weld right round yours, don't just tack it... :shock:
PostPosted: Wed Feb 02, 2005 7:04 am
Wombat,
Doc, I'll bow to your greater experience and have another go at it. I did get pretty good penetration though (oooaahhh). It's pretty much welded all around the "shafts" I'll post a close up shot tonight for the gang to critique.
Anton - Yes I made it myself and I'm a Food Scientist!!
Edit - I use a Transmig 130 I bought about 10 yrs ago.
PostPosted: Wed Feb 02, 2005 7:45 am
:lol:
PostPosted: Wed Feb 02, 2005 8:37 am
Hey Doc ANY excuse to buy another toy :wink: :lol:
David L
Users browsing this forum: Bing [Bot], watsupskip and 73 guests
