It is currently Tue Jul 22, 2025 1:58 am
 Post subject: Brake master cylinders
PostPosted: Thu Aug 21, 2008 8:38 pm
I have a few types and I was wondering if any are better that the others?
I had the one in the tray on the car but the bias started leaking so I was wanting to use the tin (bottom of pic) type, because I think it will take up the least amount of space :? what are your opinions?
Also if I use the tin type I will have to install a rear subframe mounted bias, I've seen and heard that they can be modified with a bolt in the back of them and a ball bearing to make them manually adjustable....good idea or not? (I wont be moding it myself I'll just buy one that's already done)
PostPosted: Thu Aug 21, 2008 9:04 pm
the best one is the one in the pan on the left it has a line for front and back like all the new cars have.
PostPosted: Thu Aug 21, 2008 9:14 pm
Thats the "twin circuit" design, in theory it should be safer by having two isolated circuits but I have heard from previous threads that in practice this is not necessarily the case...
PostPosted: Thu Aug 21, 2008 9:15 pm
Also I'll take one of those tin tank ones off your hands :lol:
PostPosted: Fri Aug 22, 2008 3:11 pm
The problem with the "twin circuit" set up is the bias is leaking and they can not be rebuilt :x
PostPosted: Fri Aug 22, 2008 3:33 pm
you can have new lines made and leave the leaking unit out, it really only works as a way of having the brake failure light set up with a pressure shuttle type piston set up that triggers if one side looses pressure, not really good for anything except leaking and making more connections
PostPosted: Fri Aug 22, 2008 3:51 pm
It also limits pressure to the back, does it not? If you remove it, I would fit the earlier type brake bias valve to the rear subframe - these are still available new.
PostPosted: Fri Aug 22, 2008 3:54 pm
That `FAM' valve in there is a rear bias or limiting valve, not a brake failure indicator. The rear subby had a tee not a limit valve.
Best to toss it, and fit a new rear valve instead. You can still buy these new.
As said the whole tandem MC idea was to meet ADRs, I have seen how these Mini ones don't really work.. if you don't believe me go open a rear bleed nipple and see how much pedal you get then. :lol:
The Mini King
Mini king Australia have reconditioned bias valves $150.00 exchange, If this is of any help
PostPosted: Fri Aug 22, 2008 3:58 pm
I was always of the impression that some dual circuit systems had the brake failure indicator in the master cylinder, while some had it in the bias valve. :?:
PostPosted: Fri Aug 22, 2008 4:33 pm
is there a different rear bias valve for a disc brake front compared to a drum front
PostPosted: Fri Aug 22, 2008 4:36 pm
The best one is the one with the bore that is least rooted :lol: :lol: :lol:
PostPosted: Fri Aug 22, 2008 4:37 pm
The Mini King
The cooper s did have a different bias valve to mini deluxe etc,However i believe that the standard ones work fine. The bias valve i mentioned before is for the split system Sorry i did not mention that before
PostPosted: Fri Aug 22, 2008 5:10 pm
Just keep in mind that if you use the twin circuit MC that you will have to use a tin type clutch MC. (As I found out after rebuilding my nice clubby plastic res type)
PostPosted: Fri Aug 22, 2008 6:13 pm
If I leave the tandem bias out what's the need/point of having the bulky tandem MC? and I don't have a brake fail light :wink: .
So the tandem system dose not work anyway :? you think the ADR's would have covered it working properly :lol: :roll: .
Both the tins I have are old clutch MC, will one work as a brake MC with no problems? (so long as I put a rear bias in the car).
