simon k wrote:
Wombat wrote:
Any way long story I pulled the business end off first by mistake
how do you accidentally pull the wrong end off??
This is not a Lucas pump - It looks original but is made in New Zealand and it is all black plastic. There were two fairly small screws in the back end that looked like all they were doing was holding on a yellow plastic ID number and the join between what turned out to be the end cover and the body looked like it was all moulded as one piece. I figured undo all these screws and some how it will come apart
Didn't have to add the transistor as it was manufactured with the circuit in it.(could tell by the way it was put together)
David L
