It is currently Sat Aug 16, 2025 5:24 pm
 Post subject: mini cooper id
PostPosted: Tue Aug 26, 2008 6:42 pm
Can anyone tell me if this mini is a genuine cooper
I have numbers of the id plate.
Car number260712/656
type yka251
the oringinal engine number was 9fsal10450
The engine number is now 9fsay47157 (what size is this).
Any info would be great.
Cheers bluebrik.
PostPosted: Tue Aug 26, 2008 6:56 pm
Thats an early 997 Cooper . The other engine number is a Mk1 Cooper S , the standard size is 1275
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Tue Aug 26, 2008 7:02 pm
According to PUB 1056M (Australian Mini Series Parts Catalogue) YKA2S1 is the Body Prefix for a 998cc Morris Cooper. The Engine Prefix for a 998cc Cooper is 9FA/SA/H. Whilst a 997cc Cooper has the same Body Prefix the Engine Prefix is 9F/SA/L, so yours should be a 997cc Cooper.
Engine Prefix 9F/SA/Y is for a MK 1 Cooper S (1275cc).
Hope this helps.
PostPosted: Tue Aug 26, 2008 7:12 pm
YKA2S1 is the prefix for both the 997 and 998 Coopers.
9F/Sa/L is the 997 prefix.
9F/Sa/Y 47157 would be a 1275cc Cooper S engine from about early to mid 68.
PostPosted: Tue Aug 26, 2008 7:47 pm
Hope this helps.
Have a read of TME issue 13 , its a very good article on the Aussie Cooper :D
1965 Morris 850
1977 Leyland LS
PostPosted: Tue Aug 26, 2008 8:08 pm
This cooper is a 1962 and has disc brakes and twin tanks ,is that standard? and should it have sliding windows.
PostPosted: Tue Aug 26, 2008 8:12 pm
62 Cooper has 7" discs (smaller than S ones) sliding windows and no RH tank.
PostPosted: Tue Aug 26, 2008 8:15 pm
This space for rent
Twin tanks no, sliding windows yes, I think the 997 Cooper should also have the UK long rear number plate flap.
PostPosted: Tue Aug 26, 2008 8:24 pm
AJ - TME is a great read on almost every topic. My memory brain cells continue to leave home so I find I have to go back often if I need to refresh details, and MK II S takes precedance to Cooper.
I'm lucky to have a swag of UK and Australian factory parts manuals so if I think it might help a discussion I quote what a manual says and attribute the information to the source. I'm looking to post a message that lists the numbers of all the factory parts and workshop manuals for the Australian Mini and perhaps the key UK ones, such as the Cooper and S. Do you think such a list would be useful? I'm sure my list won't be complete so there's an opportunity for others to contribute.
PostPosted: Tue Aug 26, 2008 8:26 pm
This cooper has wind up windows and twin tanks
did any coopers come out like this?
PostPosted: Tue Aug 26, 2008 8:30 pm
No.
PostPosted: Wed Aug 27, 2008 8:51 am
I'm lucky to have a swag of UK and Australian factory parts manuals so if I think it might help a discussion I quote what a manual says and attribute the information to the source. I'm looking to post a message that lists the numbers of all the factory parts and workshop manuals for the Australian Mini and perhaps the key UK ones, such as the Cooper and S. Do you think such a list would be useful? I'm sure my list won't be complete so there's an ooprtunity for others to contribute.
Sounds a good idea :D
1965 Morris 850
1977 Leyland LS
PostPosted: Wed Aug 27, 2008 9:33 am
Numbers are Cooper 997, motor is; as has been said; a 1275S.
All above info posted is good and I agree, TME article is pretty well spot on, Watto kindly asked me to cast an eye over it before he 'went to press' :P
The next set of questions should be:
Is the plate still on the original body? What is stamped on the radiator shroud and near to the plate on the bulkhead?
Does the car have three piece stainless steel wheel arch trims, 100mph Cooper speedo, what is the trim like? What type of heater (if fitted)
Definately should not have windy windows or twin tanks! :?
It is potentially an early car and would be a significant 'find'
Got any piccys? :roll:
Sir Alec! we are not worthy!
Users browsing this forum: No registered users and 208 guests
