It is currently Sun Aug 17, 2025 1:11 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Fri Aug 29, 2008 11:53 pm
Xamph wrote:
G'day All,
I'm hopefully getting a 67 round nose deluxe shell soon and my question is...
apart from the bonnet, lights and grill, will the doors, boot, interior and all mechanicals
fit from a flat nose into a round nose?
i wouldnt use a squarenose for parts if you're doing a deluxe,
there are lots of minor differences that will add up..
PostPosted: Sat Aug 30, 2008 8:00 am
At the end of the day it's YOUR Mini, there were zillions of Deluxes made, unless you want to make yet another boring stock Deluxe I would use a later motor and box.
Example- some parts for the 3 synchro gearboxes are getting scarce, a later 1098 or 998 with the all synchro box is much nicer, and has better ratios too. Fit a Mini-K box if you want to keep the remote (as you have the mountings in there now). A rodchange box will fit but is more work.
PostPosted: Sat Aug 30, 2008 9:23 am
i agree about using the engine, but the differences in the interior etc make it a pain, changing driveshafts also.
PostPosted: Sat Aug 30, 2008 10:15 am
No need to change driveshafts unless you go a rodchange box with potjoints, 74 on. Mini-K had rubber ones same as Deluxe.
PostPosted: Sat Aug 30, 2008 10:32 am
that's the first question you need to ask yourself - do you want it original or customised?
Yes many, clubbie parts fit, but they are not original.
KB
PostPosted: Sat Aug 30, 2008 11:21 am
I wont be going original... it will be customized.
PostPosted: Sat Aug 30, 2008 8:43 pm
:lol: I can't say thier are many Orginal Mini's going around unless they are Trailor Queens.
A lot were driven off the Lot and modified around the corner of Purchase
