It is currently Mon Aug 18, 2025 8:59 pm
PostPosted: Sat Aug 30, 2008 9:10 pm
Just dug up a few pics of my old 1293. I had this motor built for me back in 1997 by our one and only "Professional Mini Workshop" here in Cairns. Cost me 5 n a bit grand back in the day. For a 1st year apprentice that was a lot of coin...!
I pulled this down after a years driving at 12,000klms when i pulled my car off the road for the 2nd time.
During this motors 1yr of use I had the following problems.
Cylinder head cracked after 2 months. Replacement head fitted.
Primary gear bush let go, took out primary gear seal which contaminated the clutch. Clutch plate and seal replaced. Not sure what happened with primary gear?
After clutch replaced, suffered from clutch overthrow which stalled the motor when clutch de-pressed...! That was an adjustment issue.
When this motor was stripped, this head was also cracked.
Constant oil leak from clutch case...
So it cost me a bit to keep it running and seemed to be a lemon, but our Mini mechanic didnt seem to think so..........
What a nice surprise
So thats why the clutch case always leaked oil...
Nice wear there!
Great headjob!
Not sure how long it was like this for, I think a while?????
Warped flywheel perhaps?
PostPosted: Sat Aug 30, 2008 9:19 pm
No such thing as a Lemon unless your talking about the person that has no idea what is wrong or how to fix it :wink:
PostPosted: Sat Aug 30, 2008 9:21 pm
There still out there doing the same fine work!
Have to be very carefull who you use.
Dave
PostPosted: Sat Aug 30, 2008 9:41 pm
As i was a young teen at the time i thought the best option was to use a mechanic who specializes in Mini's. The motor thats in the car now was built by myself. At least i know theres no silastic in there!!!
PostPosted: Sun Aug 31, 2008 12:45 pm
:shock: That is dodgy...
How do you get wear like that on the bearings? Bits of swarf left on the faces?
PostPosted: Sun Aug 31, 2008 12:48 pm
They probably were not new to begin with????? I ran it for a few hundred k's with running in oil it, changed the oil/filter on it 3 times over the course of 12,000klms.
Most of the bearing shells looked pink!!!
PostPosted: Sun Aug 31, 2008 1:00 pm
5gs for that :shock: :shock: :shock: :shock: they took you for a ride :shock: :shock:
PostPosted: Sun Aug 31, 2008 1:13 pm
Plus the money i had to spend to fix it every time it broke.... I learnt my lesson in paying people to do work for me. Your better off doing it yourself.
PostPosted: Sun Aug 31, 2008 2:00 pm
Sounds like you were ripped off big time, even worse the mechanic did nothing to fix the problems. When I worked for peter (AKA bellarine mini centre here in geelong) we did 1275 rebuilds for $3500-$4500 depending on how must the mechining and gearbox cost us. And we had no complaints about our motors, and if any of our customers had a problem our fault or not we fixed it straight away. It is just good business, once a business gets a bad name it sticks.
Lindsay Palmer
06 Mazda SP23
80 Alfa GTV (weekend toy)
86 626 Turbo (daily drive, now stolen)
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sun Aug 31, 2008 2:30 pm
He fixed the problems, but i had to pay for it. I was just a young kid at the time and didnt have much mechanical experience. So i payed to have the work done by a Mini Mechanic.
He is the only shop up here in Cairns that knows anything about British auto's......apparently.....?
That $$$ figure only got me an engine rebuild. The gearbox/diff were untouched.
PostPosted: Sun Aug 31, 2008 2:42 pm
:o thats sucks. thats why im building my engine myself :D
TUCK3R
PostPosted: Sun Aug 31, 2008 4:32 pm
Hey Hanra, since I am just down the road from you now maybe next time I need a motor built, I could come and visit you????? :D
PostPosted: Sun Aug 31, 2008 4:49 pm
I could only try!!! My next engine is actually going to be built by someone who knows entirely what there doing! Ill get my hands dirty to though!
PostPosted: Sun Aug 31, 2008 5:23 pm
4000km between oil changes, ewww..... every 1000 miles for me thanks
but yeah.... seems like someone could have paid better attention to the details on that build
Users browsing this forum: No registered users and 375 guests
