It is currently Tue Aug 05, 2025 6:04 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Sep 01, 2008 6:31 pm
Leighton wrote:
i dont have lifting bracket... ill propbably make my own :D
i made mine out of some L shaped steel, i have a piece that has been cut but jsut needs the hole drilled big enough if you want it, can drop it off at your house on wednesday morning if you PM me you address
PostPosted: Sat Sep 13, 2008 10:58 pm
ok i sarted labelling wiring and nuts bolts, etc in the late afternoon today... i am now at the stage of working under the car.. can anybody tell me where the roll pin is located and what are pot joints and where are they???
is this the roll pin
cheers leighton
PostPosted: Sun Sep 14, 2008 7:05 am
Yes it is.
The Pot Joints are the CV style joints on the inner end of the Drive Shafts at each side of the Diff. Not sure what year they started using these but my 76 Clubby has them.
PostPosted: Sun Sep 14, 2008 9:29 am
thanks for that..i appreciate it.
cheers leighton
PostPosted: Mon Sep 15, 2008 5:43 pm
as you know i have rod change.....i have been told to TAP the roll pin out of the sleeve.. however i can push the rod up a couple of mm to make the roll pin CLOSE to being flush, but when i TAP the roll pin it wont budge... there is plenty of lubrication there.
does anybody have any ideas or solutions???
cheers leighton
PostPosted: Mon Sep 15, 2008 6:34 pm
not really sure what you trying to say put get a punch(forget what size someone else should know) and a few hits should have the roll pin out.
PostPosted: Mon Sep 15, 2008 6:53 pm
yer i have tried hitting probably for about half hour and the edge isnt burred.... but it wont budge its got me though... i guess ill try some more
PostPosted: Mon Sep 15, 2008 7:06 pm
Oops. The one marked in the photo is a Roll Pin, but I usually hit the other one out (sideways) as that one (marked) can hit the Diff Housing (if I recall, its been a while).
I think :?:
Dicko
PostPosted: Mon Sep 15, 2008 7:10 pm
High heel ninja
Put it into reverse, then you can tap the roll pin all the way out
Doogie
PostPosted: Mon Sep 15, 2008 7:57 pm
yeah i did put it in reverse
ill try that tommorow dicko thanks
leighton
PostPosted: Mon Sep 15, 2008 8:18 pm
This space for rent
Hmm.. I have always knocked the vertical roll pin out with the car in reverse.. sideways is too hard to get a good swing with a hammer without hitting something else..
PostPosted: Mon Sep 15, 2008 8:58 pm
Maybe I'm just Brain Dead tonight, been up since 4 something....
I honestly cant remember what I did now. Reverse does ring a bell though....
Dicko
PostPosted: Tue Sep 16, 2008 9:31 pm
today i finally got the roll pin out... just needed abit more height under the mini to get a good strike :)
now my problem is the pot joints. how do you remove them???
cheers leighton
PostPosted: Tue Sep 23, 2008 4:46 pm
on saturday i finally got the engine out...
thanks for all your help
next time im sure it will only take a couple of hours :D
cheers leighton
