Let me just say: You. Guys. Rock.
Even if it had been bad news, this is exactly the inside information I needed. I've also got all the back issues of The Mini Experience on the way.
After re-reading all the posts, I realized that I never mentioned one of the most telling things of all. The bonnet has no holes for the "S", and the newer green paint is faded to show that a normal Morris badge had been fitted, i.e. with the longer arms. The boot lid has the proper script and "S" holes. I also am 99% certain that the front fenders have been replaced, and the nose panel has some light bondo on it. Also the panel that holds the bonnet latch is just slightly tweaked.
After all the considering and talking, here's a story that I think makes sense. The original car was green/white as indicated. Somewhere early on, the car had a front end collision, which damaged fenders, bonnet, grille, nose panel. The fenders and bonnet were replaced (bonnet being non-cooper but who cares?), and the nose panel was straightened. At that point the owner decided to paint that butter cream color, OR, the butter cream was a primer all along and the owner just went straight to the metallic green that's on there now, on top of the British Racing Green. Also somewhere along the line, the oil cooler was added to the nose panel.
Years later I come along trying to figure all this out, and find that the shell is mostly intact and correct. I'll add the holes for the front "S" and put the proper Morris Cooper badge up there also. An icon is restored to its former glory.
What say you all? Sound feasible?
A few comments/questions about your latest round of feedback:
Another thing to check is if there is a small hole under the rear seat tray on the bulkhead where the electric su fuel pump vents into the car on the passenger side.
Can you be more specific--do you mean in the space behind where the passenger's feet would be? If so, there are holes into the companion boxes on each side, but nothing through the bulkhead towards the boot. The seatback bulkhead has the two clip holes, and four large holes (two high, two low) as well.
My first S was of similar vintage (1966 CAR No 1090) and was the same colour Toga White /New British Racing Green with green upholstery.
It had the engine mounted oil cooler and the vertical support piece for the grille opening, rather than the angled support as on cars with the larger grille mounted oil cooler.
Would there be anything left on the engine to show this? The vertical support is gone, since the oil cooler is now 13-row mounted on the front apron, after the apron's sheet metal was crudely bent rearward. Is the proper nose panel available still? If so, I would consider replacing this to get the right one in there.
The CAR number from the ID plate should be stamped on the firewall just below the plate and there should approx 500 difference between the CAR number on the plate and the BODY number stamped on the radiator surround.
I had to look closely behind the brake master cylinders, but sure enough, there it is: 1913. The numbers are taller than the ones on the engine and the shroud; probably 1/2" (1cm?) or so.
Looks like Seattle has aquired another Aussie icon along with Melbourne W2 trams (trolleys in US speak), along Alaskan Way IIRC.
You are correct!!! But I'm sad to say that the city stopped running the trams about two years ago. The tracks are just rusting and the stations stand empty. Not sure if they are planning to reopen the route or not, but I really miss it. It was a great way to clear out tourists also...(i.e. running them over). Happened all the time.
Yep the remote gearshift (and the old magic wand for that matter) have a spring loaded detent to prevent accidental selection of reverse. You push it hard enough and overcome the spring tension to get into reverse.
When you say "push it hard enough", do you mean push it sideways, or push it down? I'd really feel like a bonehead going to the tranny shop, "yeah, I broke reverse because I'm stupid." I broke a fire hydrant the other day, so it's not beyond the realm of possibility. At least the hydrant was stuck closed and I didn't do anything wrong...
As an aside, the 1970 of course has the factory mounted fender flares. These are starting to get brittle, and though I could save them if I had to, I'm wondering if they are available still on the market there? I have to assume I'll find lots of ads for parts vendors in The Mini Experience when it arrives, but any favorites in that regard?
Thank you a thousand times. Momentum is building again for the project. The wind was really out of my sails this time yesterday.
best,
bmc
