It is currently Sun Jul 27, 2025 8:45 pm
PostPosted: Fri Oct 24, 2008 9:36 pm
I know of a black Moke with 13" wide rims which are made from 3mm flat aluminium sheet which the owner had a 'metal spinner' spin up to the shape of the wheel,
3 pieces, the outer and inner rims then a 16mm thick spacer which bolts between them and onto the hub, the owner says they are lighter than a standard 5" alloy wheel.
He drives it on the road a lot and no problems with bending etc.
PostPosted: Fri Oct 24, 2008 9:37 pm
Give Ash some flowers Nick .
My 10x6 Mamba's are 2.75kg (rim only). I know you said they are hard to find but I think they are worth finding! Took me ages to find mine.
Otherwise these KAD ones are the lightest I have seen, you also get centrelock wheels :) One version is as light as 2.12kg! They are also "the lightest on the market". Not cheap at $1000 each though.....
http://www.minisport.com.au/prod912.htm
PostPosted: Fri Oct 24, 2008 9:41 pm
At 2.75kg, I wouldn't be stuffed machining rims!
Now to fine someone who will sell me some Mambas :twisted:
Anyone know any other rim weights?
PostPosted: Fri Oct 24, 2008 9:43 pm
If I get a chance tomorrow I'll get the weight of a dunlop , well , I think they're dunlop's , either that or Tasman's ...
PostPosted: Fri Oct 24, 2008 11:50 pm
Valtain claims that their magnesium wheels weight only 1.9kg each.
Yeah - 1.9kg!
http://translate.google.de/translate?u= ... e&ie=UTF-8
Their alloy wheels are pretty light as well... That'll be my favourite wheel 8)
Regards,
Jan
PostPosted: Sat Oct 25, 2008 1:27 am
Look at the link in Asphalt's ^ signature. Over 360 different wheels!
PostPosted: Sat Oct 25, 2008 2:36 am
Good ol` Colin Chapman (Lotus) use to say that you should design it perfectly... & then remove half the materials,,, or something along those lines :-)
not much weight in these ,,, maybe 1.2 kgs,,, but hey,,, they might be too strong for the average road car so beware what you buy :-)
PostPosted: Sat Oct 25, 2008 5:51 am
I just weighed a bare stock 10x5 Contessa (Mini offset) at 3.0kg. 8)
PostPosted: Sat Oct 25, 2008 9:29 am
I just weighted a bare stock 10 X 5 Tasman Mk2 (according to Jan's website , photo stolen below) and it weighted 3.5 kg (never thought they were that much heavier than a contesta/contessa) .
PostPosted: Sat Oct 25, 2008 3:15 pm
Ian there`s half a kilo in the centre caps of those things :-) :-) :-)
PostPosted: Sat Oct 25, 2008 8:46 pm
Damn straight! I reckon I would have 1/2kg worth of weight just in solid brass in my centre caps! :lol:
BTW Ian, that's is my spare wheel 8)
PostPosted: Mon Oct 27, 2008 12:35 pm
Original 10" Dunlop wheels weigh 3.375 kg without centre caps.
They are fairly thick so I guess it's possible to machine them.
I wouldn't, safety comes first.
PostPosted: Mon Oct 27, 2008 12:38 pm
ginger ninja
ginger ninja
hey aren't those the ones Andbat was drooling over at the Muster?
sports850 wrote:
PostPosted: Mon Oct 27, 2008 12:39 pm
Wonder how they would handle a kurb?
PostPosted: Mon Oct 27, 2008 12:44 pm
This is from the Pommy guy - don't know if I agree as I have not seen a Revo up close - especially about the 1mm off the inside of the wheel:
the rims on the revos are very very thick, normal alloys have a much thinner rim. ive machined them down to just under ths thickness of a normal alloy. ive also taken 1 mm off the inside of the wheel(the part you can not see with tyres on).
ive also taken 1 mm off the spokes. they still look the same shape. ive just skimmed over the tops to get as much metal off as possible.
to be honest most of the weight is on the rims of the wheel.
Users browsing this forum: Steam and 96 guests
