It is currently Mon Jul 28, 2025 3:19 am
PostPosted: Thu Oct 30, 2008 7:57 am
anyone done it in a round nose?
with the older doors..
i've seen it in clubys.
i have been told it can be done. with a smaller motor in the doors.
PostPosted: Thu Oct 30, 2008 8:24 am
I have seen it done on roundnose doors.
I have a secondhand kit here (was working well, when removed)
Give me a call and I can explain how it was fitted up.
-Andrew
08-8177-1275
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Thu Oct 30, 2008 8:42 am
Any chance you can post a photo of the parts?
I have no room in my doors for it but wouldn't mind a look none the less.
:D
PostPosted: Thu Oct 30, 2008 4:57 pm
I have ! I had a kit from Wood and Pickett in the uk fitted. Was kinda cool but not sure if i would do it again.
Its not the size that matters.........
Rover Mini Cooper 1993 spi - current
Rover Mini Cooper 1998 ( Tahti Blue/white)
Rover Mini Cooper 1992 ( Brg),1987 Mayfair
PostPosted: Thu Oct 30, 2008 4:58 pm
did they hide the motors in the door trays??
PostPosted: Thu Oct 30, 2008 5:01 pm
But you have a rover. The doors are slightly wider inside compared to Aussie cars.
With an aussie car the motors are most likely in the front of the door under the 1/4 window.
PostPosted: Thu Oct 30, 2008 5:11 pm
no no i have a mini travler. 1965
so where would that sit?
you could get any ones from the wreckers really..
out of a barina or something?
PostPosted: Thu Oct 30, 2008 5:20 pm
Good luck with that!
Most small cars use a rail and pulley system.
They tend to be quite wide, and the tracks are usually curved.
Larger cars and older ones use a scissor action series of levers.
I think the motor from one of them combines with the minis regulator could be possible,
but mini doors really are tiny inside if you've not had a look.
PostPosted: Thu Oct 30, 2008 5:27 pm
yes true true..
it has newer doors on it..
ive been told to do it you need to sit the motor in the tray.. ill look into it more.
PostPosted: Thu Oct 30, 2008 6:57 pm
how cool would electric sliding windows be.... :P
PostPosted: Thu Oct 30, 2008 6:59 pm
hehe yeh pimping.
PostPosted: Thu Oct 30, 2008 7:00 pm
Resident Haemorrhoid
just take the catches of them and use the go and stop pedal to open and close them :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Oct 30, 2008 7:39 pm
High heel ninja
A 65 traveller should have sliding window doors.
Doogie
PostPosted: Thu Oct 30, 2008 7:50 pm
it does.. :)
but i don't really like them..
buying some new doors..
 Post subject: Electric Windows
PostPosted: Fri Oct 31, 2008 4:45 am
There are electric window kits available that the Motor fits inside the car in the shape of an arm rest and takes the place of the winder handle. Try http://www.communityguide.com.au/commun ... ws-sydney/ They can custom fit electric windows to anything. I buy kits from them.
"Let us remove your "SHORTS"
