mini1989 wrote:
sorry to continue on, due to insurficient tools. I only managed to undo one locking nut. Then I detach the wire so I can give it a try but no luck couldn't turn it al all. Maybe I am suppose to unlock the other nut as well. Strangly the two wires that connected to the switch is that suppose to connect to the reverse lights or the inhibitor switch at the front of the engine? When I unplug them the car won't start even though it is in P. If I disconnect the wire at the front of the transmission that connects to the inhibitor switch the reverse lights will not work at all but the car still starts? Just to inform that the wiring has been modified by some electrican somehow he doesn't know what's going on.
It sounds to me like you have the inhibitor switch plugged into the reverse light circuit and the reverse light circuit plugged into the inhibitor. The switch on the front of the gearbox is definitely the inhibitor switch.
Is your shifter a plastic top one like this?
