It is currently Thu Aug 14, 2025 3:05 pm
PostPosted: Sat Nov 08, 2008 12:36 pm
Rover Cooper
Just make sure you get a good quality
oil filter spray supercrap sells a good spray for a good price, don't use the filter dry, its wont last long and its harder to wash out in soapy water, which is all you have to do, with oil it will last for years without having to change as long as you wash it regularly.
PostPosted: Sat Nov 08, 2008 12:46 pm
Supercharged
is that an air pressure sensor on the intake?
i'd prefer to find a k&n element for the stock box
PostPosted: Sat Nov 08, 2008 3:41 pm
I'd also like to keep the stock air cleaner, I think it looks better than the chrome K&N job.
But if I can get a few more ponies and a nicer sound with the K&N then I better order one:D
Image Image
PostPosted: Sat Nov 08, 2008 3:54 pm
Rover Cooper
Get one just for the sound....nearly as good as a Webber.....Nearly..... :wink: :wink: :wink:
PostPosted: Sat Nov 08, 2008 4:28 pm
It's the box that's the problem.
Replacing the filter only will do sweet FA.
If you wan to keep the stock box your only option is drill a rather large amount of hole in it......I'd only do this if I had a spare box.
I bought mine purely for improved performance, how my engine bay looks isn't of any concern to me, the less time I see my Mini with it's bonnet up the better.
PostPosted: Sat Nov 08, 2008 4:41 pm
Die Die Die!!
you rekon thats bad maxi have a look at a stock one.. yours had the extender pipe missing...
 Post subject: Re: SPi - K&N Filter Kit
PostPosted: Sat Nov 08, 2008 5:58 pm
Maxi23 wrote:
Maxi23 wrote:
It HAS to be better than the stock intake ? surely ??
Holy crap, it certainly is.
This, combined with new leads has made one hell of a difference.
3000+ RPM and you can tell the difference, the sports cam loves the increased air flow.
Sports cam? What sports cam did you get? (ears perk up!)
Where and how much?
Noli Illegitimi Carborundum
PostPosted: Tue Nov 11, 2008 8:52 am
I would disagree - originally, my cooper would not rev passed 4k and with the 57i fitted, it will happenly go to 6+ ( more probebly but don`t want to work the motor to hard ) It revs quicker and more freely and feel alot more perky so i would say it really does improve overall performance.
Next step is a good quility LCB
Its not the size that matters.........
Rover Mini Cooper 1993 spi - current
Rover Mini Cooper 1998 ( Tahti Blue/white)
Rover Mini Cooper 1992 ( Brg),1987 Mayfair
PostPosted: Tue Nov 11, 2008 9:17 am
I've heard from a few people in the past that the best power gain comes from fitting an aftermarket element (eg K&N or whatever) into the STOCK airbox.
Anyone compared that to the replacement unit before?
PostPosted: Tue Nov 11, 2008 9:37 am
actually i have - Its been said before ( Mini Mags - Kieth calver ) that the best combo is the stock box with a K&N eliment and holes cut in the side to increase airflow. I tried that already and liked that set up but after trying all three, i think this is the best set up so far. Sounds the best which for me is 50% of the reason why ;-)
Users browsing this forum: Bing [Bot], crisonic and 195 guests
