It is currently Fri Aug 15, 2025 6:29 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sat Dec 13, 2008 4:23 pm
Slow-Po
Interesting article that tests the (false) economy and power benefits of e10 v unleaded v premium.
http://www.drive.com.au/Editorial/Artic ... =2&IsPgd=0
PostPosted: Sat Dec 13, 2008 6:27 pm
Another reply from the manufacturer of the carby kit, they say that the hose was rated for 91-95 octane fuel. The manufacturer of the hose has never had any problems with the hose getting brittle and spliting.
But they said that E10 or 98 octane fuel could be a problem. So they are testing a bit of hose in ethanol to see what happens.
They are going to report back to me. :D
PostPosted: Sat Dec 13, 2008 6:29 pm
Would this kit be the Fuel Miser one?? :wink:
I've used these with 98 and 95, never had a problem.
PostPosted: Sat Dec 13, 2008 6:41 pm
:wink:
And I used one tank of E10 and it all turns to crap. :lol:
PostPosted: Sat Dec 13, 2008 6:48 pm
Well, there will be a lot of us in poo/crap if they make ethanol compulsory in all fuels... :mrgreen:
I wonder if my 45 Dellorto would fare better.. hmmm...
PostPosted: Sat Dec 13, 2008 6:59 pm
It just means that we will have to work our way through the car as things stuff up and find replacements.
PostPosted: Sat Dec 13, 2008 7:04 pm
Hopefully the car doesn't catch fire during this process. :wink:
PostPosted: Sat Dec 13, 2008 7:12 pm
But at least with E10 it will be better for the environment as it burns to the ground. :mrgreen:
PostPosted: Sat Dec 13, 2008 7:20 pm
Heya Wombat (le pharmacist extraordinaire), can we crack this E10 stuff and take the ethanol out? Then we can drink it, and the cars will run fine, no more problems. :mrgreen:
PostPosted: Sat Dec 13, 2008 7:23 pm
Could we turn the ethanol into hydrolastic fluid and solve two problems? 8)
I bet you strain your Brasso for the alcohol right?
BTW, Isopropyl alcohol and orange juice do not make a nice drink. Don't ask me how I know...
PostPosted: Sun Dec 28, 2008 4:22 pm
I have had another small fuel leak in the car since the single tank of ethanol, I don't know if it it related to the fuel or not but I suspect that it is.
The mechanical fuel pump started leaking from the screw in the middle of the top cover. It just took a little nip with a screwdriver to tighten it up and stop the leak.
Under the screw is a fibre washer, under the top cover is a gasket. I would guess that either the washer or the gasket have shrunk a little from the fuel.
I guess it is a matter of keeping an eye on everything to see what leaks next. :?
PostPosted: Sun Dec 28, 2008 8:02 pm
I did a fairly disorganised economy test with my employers 2000 petrol Pajero
empty trailer to Melbourne - 360km - 3/4 of an 80 litre tank of E10
full trailer from Melbourne - 340km - 2/3 of same 80 litre tank of 92
PostPosted: Sun Dec 28, 2008 8:10 pm
was filling up at the bowser the other day. I was using premium as always. Saw E10 and it had a warning on it that said do not use for any cars older than 1985. This was at shell
PostPosted: Sun Dec 28, 2008 8:38 pm
What are you going to do when all petrol is E10? It may happen. :cry:
Users browsing this forum: bharp831 and 163 guests
