It is currently Wed Jul 16, 2025 11:36 am
PostPosted: Thu Nov 06, 2008 8:52 pm
ausmini mod
ausmini mod
Hi,
Cool :)
No, I dont think it will affect clutch operation - but I think it will be a nightmare trying to bleed the clutch fluid on the slave cylinder :) I know mine is ;)
So running the RE7 ay :) That was my idea - until we started and GR walked away and said "Good luck Pete, not a chance" :lol:
I didnt want to cut the firewall to fit it. I would guess you will cut the firewall right?
What size is the dump pipe off the turbo?
Pete
PostPosted: Sat Nov 08, 2008 9:04 am
Just another thought, could you mount the radiator on the drivers side inner guard? Cut the grill part off an old passenger side guard and with a bit of creativity you have two radiator mounts :)
PostPosted: Sat Nov 08, 2008 3:33 pm
Pete the dump pipe off the turbo is 2 1/4" for the first bend then reduces to 2" to fit between the engine and subframe. The dump pipe is actually the one part of what I had made that I'm 100% happy with. I'm seriously considering changing to a clubby front for the extra room though and rethinking the layout of pretty much everything under the bonnet. :? (would have been smarter to have decided this a bit earlier, but I'm sure this won't be the last changing of minds that I have during this project :oops: )
Abbino235 It's idea's like that which is why I read the posts on this forum :D I will certainly be doing some measurement in the future in regards to this idea.
Pete
PostPosted: Thu Nov 13, 2008 5:56 pm
looks good , totaly different to how i expected it to be made :)
cant wait to see it finished need more turbo minis
around here, and stick with it roundnose and all it will work out and would be tight fit no matter.
PostPosted: Thu Nov 13, 2008 6:10 pm
Appreciate peoples positve comments but I just don't like it :( So went around to GR place the other day to check on the progress of the head (202) and got talking about alternative idea's and out he pulls this turbo/inlet manifold that a 60's era (I think) race car used. :lol:
[/img]Image
[img][img]http://i438.photobucket.com/albums/qq102/nanook73/IMG_2149.jpg[/img]
Now the manifold can't be used by me but the concept and placement of the turbo and inlet manifold got me seeing a lot of my space issues being sold. The carby will be placed where the turbo was originally going to be. No issue's with that according to Graham :) [/img]
PostPosted: Thu Nov 13, 2008 6:21 pm
Didn't release you could run out of post space :o Unlike the manifold shown in the picture the inlet manifold for want of a better word will be a log type arrangement. These are some photo's of the rough position the turbo will be situated in and this time Mr enforcer will be tasked with the job of both manifolds. If it works out as planned their will be no bulk head or bonnet mods needed :lol: The turbo needs to come in and down 1/2" from the photo's to clear 8) Also to the right to line up with 2&3. (Dump act just sitting loose.
PS Ben GR said I should look at your arrangement with the turbo over near the passenger side. Have you got any photo's???? Overall I feel this is a better concept? Open to negative comments with arrangement :D
[img][img]http://i438.photobucket.com/albums/qq102/nanook73/IMG_2154.jpg[/img][/img]
[img][img]http://i438.photobucket.com/albums/qq102/nanook73/IMG_2153.jpg[/img][/img]
PostPosted: Fri Nov 14, 2008 9:43 am
I reckon keep the roundie shell they look better anyway
Also make sure you keep us updated with pictures throughout the process :D . It seems as though your redesigning the whole system there. Have you looked at the other long turbo thread on here and seen how that one is set up?
http://www.ausmini.com/forums/viewtopic.php?t=37604
He had his turbo located over the clutch housing...
 Post subject: Jay
PostPosted: Thu Dec 18, 2008 5:33 am
you might want to have a look at mine... since this picture i have made a new inlet mainfold ie, from the turbo to the webber... that keeps it alittle closer to the block and facing more towards the grill.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Thu Dec 18, 2008 2:32 pm
Nanook73....Is that the smallest ball bearing turbo avaliable?
PostPosted: Thu Dec 18, 2008 8:55 pm
ausmini mod
ausmini mod
Hey mate,
Looks like you have changed turbos?? Doesnt look like the 2554 anymore unless im way too tired and seeing things wrong.
Pete
PostPosted: Thu Dec 18, 2008 9:52 pm
Pete its the same turbo and I was informed by the turbo mob CGC or GCG? out at Condell Park Sydney that it is the smallest ball bearing currently available by Garrett (whether that is 100% I'm not sure).
Clubmn my carby will be in a simular position as yours but will be blow through. The car is being taken out to a buiness called OZ RACING in January and then the action should start and things should be clearer in regards to how the engine bay componets will be set out. I've pretty much have the main ie expensive bits gathered and will attempt to put together a bit of a build thread in the new year for those interested, until then have a safe and merry christmas.
Pete
PostPosted: Fri Dec 19, 2008 12:19 am
ausmini mod
ausmini mod
Hey Pete,
Ok. it ,must just be me then lol
That IS the smallest ball bearing turbo - thats for sure. Its GCG - a mate of mine is sponsored by that mob.
Good luck with the build!
Pete
PostPosted: Fri Jan 23, 2009 5:40 pm
Milatsmadmini
Gday Nanook73
just wondering how your build is going... i am pretty keen to get a little 998 turbo in the works soon and just trying to establish what setup to use and where to mount etc... oh btw its goin in a moke :wink:
Im curious... why werent you happy with the log manifold?
