It is currently Thu Jul 24, 2025 6:32 am
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon Dec 29, 2008 7:40 pm
i have stripped most of the exterior down of the clubby- i tried por15 metal ready and this just oxidodises by the next morning.
any other ways? ideas? help?
cheers leighton
PostPosted: Mon Dec 29, 2008 7:52 pm
anything you apply to stop it flashing off will be a real pia when it comes to painting time. I just cut the paint back and went over the exposed metal with a scotchbright pad everyday until I had it all the paint off and I was ready to prime it.
PostPosted: Mon Dec 29, 2008 7:53 pm
I just worked panel by panel. Removed old paint. Went over surface wirth 180 wet and dry paper (wet). Treated area with a deoxidiser solution. Rinse with water and dry and then paint within an hour with a Wattyl epoxy etch primer. This will seal for several months and can be overcoated with primer topcoat.
Hope thats a starting point.
Dave K.
PostPosted: Mon Dec 29, 2008 8:01 pm
ok awesome i think ill go with biam's concept as i dont have the equipment at my house but at my uncles bout 1 hr away.
thanks
PostPosted: Mon Dec 29, 2008 8:19 pm
The guy who beadblasted my shell for a restoration treated it with what he called "Keyphos" - the shell sat in bare metal without rusting for months whilst the various repairs were done prior to painting/priming.
KB
PostPosted: Mon Dec 29, 2008 8:25 pm
spray wd40 all over it - helps to protect it- thats what im doing.
But im working on it daily
Brenton
PostPosted: Mon Dec 29, 2008 8:34 pm
I knew a guy who did a resto recently. He simply wet a rag down with petrol and wiped it liberally over the bare surfaces. It seemed to work well.
PostPosted: Mon Dec 29, 2008 9:21 pm
ok.
what can you use to remove the petrol or wd 40 come 'prime time' :D
PostPosted: Mon Dec 29, 2008 9:26 pm
For the last few years I have been able to leave bare metal in the shed without any rust forming. The drought had a few advantages.
PostPosted: Mon Dec 29, 2008 9:30 pm
Leighton wrote:
ok.
I'd use wax and grease remover. Wipe on, wipe off. Done! 8)
PostPosted: Mon Dec 29, 2008 9:41 pm
Boyracer wrote:
Leighton wrote:
ok.
How do you get rid of the WD40 and petrol that will bleed out of seams and joins when you paint the primer on? :D
PostPosted: Mon Dec 29, 2008 10:05 pm
My car sat for a month or so after it had been blasted back to bare. Im not sure what it was covered in but it looked like this. Ill hit my mate up next time Im talking to him and ask him what he covered the car in.
PostPosted: Mon Dec 29, 2008 10:10 pm
ok sounds good thanks
PostPosted: Tue Dec 30, 2008 9:10 am
Etch primer has been working for me. I think that might be what 1310/71 is refering to with 'keyphos'.
PostPosted: Tue Dec 30, 2008 9:28 am
cheers leighton
I've had my shell sitting in por15 metal ready for some time and there's been no problems... Are you keeping your shell outside at all?? Also did you clean the surface with marine clean before using the metal ready? Any pics...
I'd stay away from using WD40 as it has silicone's in it and paint doesn't go well with silicone... you could always do one panel and then prime with an epoxy primer if that is easier
