It is currently Tue Jul 01, 2025 12:00 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Feb 15, 2005 4:57 pm
P-plater and can't say sorry :lol: :lol: :lol: :lol: :lol:
PostPosted: Tue Feb 15, 2005 5:01 pm
:lol:
Just like the PM :wink:
PostPosted: Tue Feb 15, 2005 5:02 pm
Bloody P-Platers
OI !!!!!
Easy... This p plater is resposible and i only ever race people to the other side of the traffic lights :twisted:
but really, its not p platers it just people who have no understanding in car control and too much bloody money! Every day I almost get cleaned up by a little old lady or a 4WD owner, but its the p platers that are the problem... hmmm
If driver education is low in all areas, of course the youth are going to crash alot, but these days everybody does.
I work in spare parts and i get at least 20 people a day coming in with car park drive bys.... whos teaching these people how to drive and the laws involved in leaving an accident???
Time to try drifting,
PostPosted: Tue Feb 15, 2005 5:04 pm
Stop that NOW!!!!
We don't want another one of 'those' threads :wink:
PostPosted: Tue Feb 15, 2005 5:35 pm
so from the vibe im getting is, straight cut gears = keep to the 1380 racers? :wink:
PostPosted: Tue Feb 15, 2005 5:38 pm
and earmuffs coz they're so freaking loud. :) :shock:
PostPosted: Tue Feb 15, 2005 6:15 pm
I'm not having a go at Anyone (not that I have been accused) I just think that sort of money can be better spent in other areas of your car. To me straight cut gears on a road car (or even a race mini that's not a full on prefessional mega bux job) are overkill for the $$$$
When you are cruising along in a car with SC gears the power is not always going trough the gears, like when you are coasting, and that's when they make a HEAP of noise.
PostPosted: Tue Feb 15, 2005 6:17 pm
Yeah.
Whats a (performance) mod for under the 600 mark then?
PostPosted: Tue Feb 15, 2005 6:28 pm
600 dollars worth of headwork would be a good thing, of corse you should have a decent manifold and exhaust to make the most of it.
Aaron
PostPosted: Tue Feb 15, 2005 6:35 pm
Ive got a set of Perry extractors... 3-1
The inlet manifold hasnt been modified at all... just a stockie 1.5 i think.
I have a JUN BL exhaust, so no worries there :wink:
What does head work cost? Valves enlarged, valves and guides to suit, etc.
THen a new ringset would be advisable yes? Or not?
PostPosted: Tue Feb 15, 2005 7:00 pm
skssgn wrote:
the gears are much stronger, takes the punishment of extreme extreme power and race motors with big torque..... instead of the teeth on the gears being cut on an angle (helical) so they mesh better when changing gears, the teeth are cut straight across, so they mesh better when engaged, which makes it a ning nong to change gears - they will always crunch
Simon....
You are maybe thinking of a dog box- they crunch, but even they have all the gears in constant mesh- the gears themselves don't slide into mesh.
The gears in any 4 synchro Mini box are in constant mesh, regardless of whether S/C or helical. And the synchro setup and selectors etc is the same in both.
Yeah they whine a bit, but most of the racket is the S/C primary gears which the racers all use.
1st gear in a 4 synchro Mini box is already S/C, and it's not real noisy is it.. :wink:
re. driving a SCCR box on the street- 1st gear is taller so it's a bit harder to get away fast, unless you drop the diff ratio. And then it'll scream its nuts off on the freeway.. :lol:
My next motor (1360cc+) will have one, and a 3.76 diff. Just for fun.. :P
But use a dog box on the street? Forget it... :lol:
PostPosted: Tue Feb 15, 2005 7:58 pm
High heel ninja
I've got a straight cut close ratio box, it's bolted too my 1427 stroker motor, its your for the right money.
Doogie
PostPosted: Tue Feb 15, 2005 8:44 pm
The main reason SC gears are used is because of the better, closer, gear ratios available. Properly set up, they do not crunch. As Kev says, it is the drop gears that generate most of the noise. For the road, Mk 2 S gears are probably the best you can get, don't need SC except for the pose value. Steve
PostPosted: Tue Feb 15, 2005 8:54 pm
Simon....
:D I've got a lot to learn about gearboxes.... gotta have a go at rebuilding one, but both of mine are perfect so I'm not gonna screw with 'em just yet
so what is it that makes straight cut gears stronger? what I was trying to describe was that the teeth are in contact all the way across with s/c, but with helical the contact moves from one side of the tooth to the other as they rotate - did I get that wrong?
PostPosted: Tue Feb 15, 2005 9:11 pm
In theory, SC gears are not stronger, size for size. There are shock loads as the power is transferred from tooth to tooth, and they are not as smooth as helicals, which have several teeth in mesh at once..
However, the teeth in a SCCR box are generally slightly bigger form than a Mini's helicals.
Also, due to the short production runs required, they are manufactured on equipment that is crap compared to that used by industry to produce helicals. So, they wear faster. Some gearsets are noisier than others.
Benefit for racing (apart from close ratios) is there is no end thrust generated in the bearings as there is with helicals.
This end thrust=friction=loss of power. How many gee gees are saved, I have NFI.
BTW back in the mists of time,(3 synchro boxes) there were close ratio helicals available. But these have been NLA for yonks. :wink:
Users browsing this forum: Bing [Bot] and 93 guests
