It is currently Tue Jul 22, 2025 7:26 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Mon Jan 05, 2009 6:13 pm
Just wondering if anyone on here could help me in getting any info etc. about my car ie what year what type etc.
I have been told by the previous owner he thought it was a 64 however the rego paper says 69.
Allthough it does not have sliding windows? i know doors can be changed though.
obviously the pencil is pointing to where the numbers i found are :D
the number i found here was,
42348
but my girlfriend was convinced it said...
48848 :roll:
the number on the firewall was
42149
Also where abouts would i find the engine number besides my rego paper - Which i cant seem to find so i wont know until i get my renewal :oops:
PostPosted: Mon Jan 05, 2009 6:22 pm
It's mid 68 or later, by the wiper setup.
With numbers that high I'd say either Mini Deluxe or Mini K.
PostPosted: Mon Jan 05, 2009 6:27 pm
the wiper motor was just replaced would that make a difference? :lol:
PostPosted: Mon Jan 05, 2009 6:32 pm
No, the holes in the body where the wipers are mounted changed in mid 1968.
Before that they parked on the drivers side.
Engine number is stamped on top of the engine block, near #1 spark plug. below the top rad hose, in your pic.
PostPosted: Mon Jan 05, 2009 6:35 pm
Mini K numbers never went as high as that.
It must be a Mini Deluxe.
They changed the wiper direction in mid 68 with car number 32800.
I would say that this car is a very late Deluxe, so it would be mid 69.
The number near the radiator is the body number.
The number on the firewall near the master cylinders is the car number.
This is the important number, this should match the rego papers (unless they stuffed up and used the other number!)
The two numbers should be around 500 apart. The number on the firewall should be higher than the other number.
PostPosted: Mon Jan 05, 2009 7:13 pm
checking again with a torch at an angle the body number is 42342 but the one on the firewall is definatly 42149 :?: still the body number is higher than the firewall one :? :?:
Trying to read the engine number is very hard with the paint to the best i could make out was 12YD1TaH 578 with a few bits missing? :?
PostPosted: Mon Jan 05, 2009 7:20 pm
I would not worry too much about the differences between the numbers. They were about to change the numbering system in a short time and they changed it again a year later. Your car may have had the body and car numbers the other way around for some reason.
The engine number would be 12YD/Ta/H 578*. This is a Morris 1100 S motor.
They only made about 15000 of them so the highest number is in the high 15000s.
PostPosted: Mon Jan 05, 2009 7:39 pm
Oooooooo Hold the presses.......
It may not be a Deluxe at all. :shock:
Looking at the photos the car looks a lot like an early body with the late wipers stuck on. I am thinking it may be a Mini 850.
I wish I could see the car in person to check all the details. :?
PostPosted: Mon Jan 05, 2009 7:45 pm
High heel ninja
Please fix the bonnet badges, they ruin a nice car.
Doogie
PostPosted: Mon Jan 05, 2009 7:48 pm
Doogie
:lol: I was looking at the front thinking something looked wrong but couldn't place it ... Your badges are the wrong way around , s goes above the other .
Anyway , back on topic , look at the valance/stone tray , no cutouts at the side so it's an early 850 .
Doogie
I know i know :lol:
Its on the the to do list, but the way the badges are stuck on its a bonnet respray job :cry:
is there anywhere i can photograph for you Morris 1100 to give you a better idea?
PostPosted: Mon Jan 05, 2009 7:50 pm
Doogie
He has to work out if the car is an 850, Deluxe or a K before he can change the badge. :lol:
I think we should pass a rule that if a car has a Morris 1100S motor it should run the S off the 1100S. 8)
PostPosted: Mon Jan 05, 2009 7:52 pm
Doogie
Way over my head hahaha :P
PostPosted: Mon Jan 05, 2009 7:53 pm
Doogie
now that would show some respect
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Mon Jan 05, 2009 8:01 pm
Doogie
Does this look better? :mrgreen:
Users browsing this forum: Bing [Bot], rhaj and 83 guests
