hello all,
FINALLY got around to installing my speedo cable today (spins up the top but speedo doesn't work. busted speedo?), and in the process I managed to come across this loose blue wire. does it go into that black thing?
is it for the temp gauge? because that's not working anymore. i tried it in the black thing but nothing happened. would that be because the copper part is missing? i don't think it was there when i pulled the cluster out. the amount that it is stripped suggests so. but this also suggests that putting it in there in such a way that it bends around would make the relevant instrument work fine?
also, i think i broke this blue thing, in the pic just above where the globe holder is supposed to go. is this for the right indicator bulb? because that's not working anymore either (and not because the globe is missing
). what is this part called, and can it be fixed or do i have to buy a new one? i reckon it will be expensive...
i had a look at the wiring diagram but it does not list a plain blue wire... is this a replacement with whatever the person had at the time? if it's for the temp gauge shouldn't it be green?
i think that's all, I'll keep going and see what i can do.
cheers chaps and chapettes
