It is currently Sat Jul 19, 2025 8:45 am
 Post subject: compatabilitys ?
PostPosted: Sat Jan 17, 2009 5:27 pm
Hey first post, sorry if its been asked before
is there any common leyland parts that fit onto a morris like the doors or motor parts other than pulleys, flywheel, timing gears?
i got a bunch of stuff off an old mini enthusiast like doors a 998 complete motor a gear box and parts flywheels etc
wondering if i could put em on me car be it for weight reduction or better efficiantly
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Sat Jan 17, 2009 5:46 pm
I doubt you'll save much weight if any and it wont be any more efficient but the engine should bolt straight in the doors you may have an issue with depending on what your mini is.....what is your mini? if you really want to know post some pics up of the doors etc.
PostPosted: Sat Jan 17, 2009 8:00 pm
1969 morris with: deluxe doors?
want to put on the yellow leyland pull up handle doors
Image[/img]
PostPosted: Sat Jan 17, 2009 8:21 pm
The door striker mechanism is very different (as you can see) but the B pillar panel is different too . It can be done but will need a lot of surgery with sections cut out of a donor mini .
PostPosted: Sat Jan 17, 2009 8:22 pm
well out of the assorted parts i put together a
lighter fly wheel & the flywheel plate with the keyway
the lightend pressure plate
race clutch
a pressed steel crank pully
and a lighter timing gear in it to
i want to reduce the engines rotational inertia as much as i can like the parts with more holes drilled in them weight etc.
i also have 45 webbers to go on it
thanks sports 850 i was afraid of that
PostPosted: Sat Jan 17, 2009 8:52 pm
The pressed steel crank pulley is a good way to save weight.
If you use one of them you can usually throw the crank away. :mrgreen:
If you want to save weight why are you fitting 45 webbers to it? Surely one weber is enough?
(and you can save extra weight by leaving out the surplus B) :lol:
PostPosted: Sat Jan 17, 2009 8:55 pm
it came with the 45 webbers on the old 1275 that came with the car
im yet to pull apart my collection of su carbs to sus out how they work!
i always pull stuff apart before i use em,
but not if they are straight from the box lol
PostPosted: Sat Jan 17, 2009 9:11 pm
Whoosh
PostPosted: Sat Jan 17, 2009 9:34 pm
Building the engine with lighter components can be a good idea so long as their still strong enough for the job. It should make your engine rev easier so you'll reach max bhp quicker but you will loose torque :roll:
Like sport 850 said the doors wont fit but all the glass and winding mechanisms are interchangeable, locks and handles are not.
PostPosted: Sat Jan 17, 2009 10:09 pm
I thought an engine with 4 Webers was impressive!, Would be an interesting manifold, 22 webers off each runner with a "split" one thrown in for good measure! :lol:
Andrew
PostPosted: Sat Jan 17, 2009 11:32 pm
Best way to reduce rotational inertia is to lighten the flywheel. You can also lighten the rods a fair bit. GR did the machining on mine and did a great job.
I wouldn't switch the harmonic balancer for a lighter pulley, you will probably end up breaking the crank. I broke 2 cranks in my 1100 Mini many years ago before I discovered it had the wrong pulley.
Pete
PostPosted: Sun Jan 18, 2009 10:27 am
ok so puting the harmonic ballencer back on is advised
but has anyone swaped the master clylnders from a morris to leyland ones
because i thought instead of having a brake booster id just rig up both exits to a T piece and run that to the front/rear T piece
as shown
PostPosted: Sun Jan 18, 2009 12:58 pm
Check the harmonic balancer is not deteriorating in the rubber between the two halves (inner and outer) any cracks and it will need refurbishing
David L
PostPosted: Sun Jan 18, 2009 3:14 pm
If you like the clubman style door handles, then look at some of a 80 series landcruiser. They fit into clubman doors with a bit taken out of each end. Leave the original door locks in, it will confuse any one trying to steal the car. 2 door locks!!!!!!
You could cut a new hole and fit them to the deluxe doors. Get the ignition switch as well then there is no problems in getting keys cut.
The landcruiser inner handles also fit into clubman doors
www.minisprintgt.com
PostPosted: Sun Jan 18, 2009 3:48 pm
as shown
Ummm, please don't do this. You do not have a clue, you are going to hurt yourself or somebody else.
You are trying to fit a dual circuit master cylinder to a single circuit. Why on earth would you want to do that? :shock:
