It is currently Fri Jul 18, 2025 10:59 am
PostPosted: Tue Jan 27, 2009 2:15 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
plasma cutter and clean it up with a grinder, (angle or bench)
https://t.me/pump_upp
PostPosted: Tue Jan 27, 2009 2:23 pm
Hydraulic press with custom made die! (jokes)
These brackets are small, they would only just overhang a 50 cent piece, so an angle grinder would make it pretty difficult, so would a plasma cutter.
PostPosted: Tue Jan 27, 2009 2:31 pm
Get them lasercut and put a fold in it!
Quick and simple!
I'll make you a DXF tonight if you want!
:D
PostPosted: Tue Jan 27, 2009 3:06 pm
doesn't everyone have a 2m wide hydraulic guillotine at work? ours is set up near the 300mm cold saw, near the pan brake (sheet bender)
Ian, I made my carb heat shields out of (roughly) 2mm aluminium - with the extractors at 240* C, I can touch the back of the heat shield.... works good
PostPosted: Tue Jan 27, 2009 4:36 pm
I bought one of these the other day - only cause I thought it would be useful for cutting rust out of the Moke shell but it may work for what I've got in mind at the moment.
David L
PostPosted: Tue Jan 27, 2009 5:06 pm
i use a plasma cutter, die grinder, 4' angle grinder with the thin discs,jig saw etc. whateva works.
Have a Nice Day.
PostPosted: Tue Jan 27, 2009 7:05 pm
I had an hour spare today so I decided to write a program and cut some out on the cnc.
Here's the result!
Available to Ausmini members if you are interested.....
Dave
PostPosted: Tue Jan 27, 2009 7:51 pm
Good on ya Dave, well done.
I love this forum, ask and you will receive. :)
PostPosted: Tue Jan 27, 2009 8:32 pm
I used to work in sheet metal. We would get little jobs like this in all the time. Doesn't cost much, especially if the customer has brought in his own sheet and marked it all out. We would just use the hydraulic guillotine and a nibbler, then just fold it in the bender.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Jan 27, 2009 9:10 pm
Dave (sitnlo62) you truely are a most wonderful person,,,
if only you were female :-)
Users browsing this forum: Bill B and 99 guests
