It is currently Fri Jul 18, 2025 4:27 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Jan 31, 2009 8:18 am
Is this the type I need? 25 x 10 x 3mm neodymium
Flute - 68 MK I Cooper S
Member: VMCI #2474
No you want 25 diameter by 10 thick. :wink:
Or bigger....
PostPosted: Sat Jan 31, 2009 8:27 am
OK, need to source that from somewhere, Davo111's site has them thicker but I guess you dont want it too wide or it will be too big for the filter and likely to come off. Is the neodymium part right or just any type?
Member: VMCI #2474
PostPosted: Sat Jan 31, 2009 9:06 am
Make sure they are neodymium (aka rare earth). Std magnets do not have the oomph to penetrate the case and hold the swarf.
PostPosted: Sat Jan 31, 2009 10:36 am
Try this page.
Cheers Pete
Try this page.
http://www.maglabmagnets.com.au/search. ... rare+earth
Cheers Pete
PostPosted: Sat Jan 31, 2009 10:46 am
Cheers, so any one that is neodymium and 10mm min thick, doesn't matter if disc or rectangle. Maybe rectangle sits flatter on the filter, longer but narrow. Sorry to make this simple thing so complicated, just wanted to know what the go is before I fork out any $$$. I will put one on each side of the filter and then see how much it picks up next oil change.
Maybe this one
50 x 20 x 12.5 mm @ $34.63, not cheap but then an engine rebuild is dearer.
Member: VMCI #2474
PostPosted: Sat Jan 31, 2009 3:23 pm
Yep grab one of those and it'll cling to the side of the filter like a Limpet mine. 8) One is plenty.
PostPosted: Mon Feb 02, 2009 8:45 pm
Will do, cheers! Had to look up Limpet too!
Member: VMCI #2474
PostPosted: Wed Feb 04, 2009 8:34 pm
For those interested and who that suggested the "rare earth" magnets I purchased 1 for each of my cars today from "Aussie Magnets" in Camberwell melbourne. The most suitable size I found up against an actual mini oil filter was $30 per magnet. And considering I had no true understanding of the power of these magnets, it was unblvble !, As I said I purchased two, I pulled them apart to show a friend and as I pulled them away from each other, they snapped back, I have a blood blister on my finger like I hit my had with a hammer, I'm a 30 yr old healthy male and it seriously takes two hands and a extreamy good grip to pull them apart from each other, And I you have any doubt about it pulling the "swarf" through a filter housing, go buy two magnets and put them together and you understand..... Well worth $30 for an additional piece of "oil insurance" for your motor ( my last motor costed me about $10k), Worth a try !
Thats my opionion anyway, Cheers
1964 Grp Nb Cooper S
1976 911 3.6 Circuit Car
1969 911T Grp Sb Historic Racer
2009 LC200 V8 TDI.... 660nm..
2011 Golf VI, TSI
PostPosted: Wed Feb 04, 2009 8:46 pm
Keep these magnets well away from your credit cards... unless you want them wiped for good. :lol:
If you cut a filter up after a thousand miles or more with these magnets on, you will not believe all the stuff these things collect.
Filters do not stop everything, any particles smaller than around 50 microns just go round, and round, and round... unless a magnet catches them. :wink:
<edit> typo
Last edited by drmini in aust on Wed Feb 04, 2009 9:36 pm, edited 1 time in total.
PostPosted: Wed Feb 04, 2009 8:50 pm
After I paid the lady in the shop I put the two magnets in my R/H/F pocket and as was about to put my wallet in my R/H/R pocket, the lady suggest that i carry my wallet to my car in my LEFT hand.... she wasn't smiling either !, She was serious !......... I guess its safe to assume that the magnets probably work........
2011 Golf VI, TSI
