It is currently Tue Jul 22, 2025 1:57 am
 Post subject: gasket questions.
PostPosted: Thu Feb 05, 2009 12:06 pm
Hey all,
This is probably a n00b question but I have searched and can't find the answer. This may be coz I am searching for the wrong thing though.
I am fitting some new gaskets on the weekend when putting things back together ( water pump, screw on filter and a couple more). I have got new gaskets and was wondering if I have the correct procedure.
1. remove old gasket using a razor blade.
2. Clean up both surfaces with fine emory or sand paper.
3 put on gasket ( not sure if any adhesive should be used here
4. tighten bolts the the correct torque.
Do I need to do anything more and do people use any sort of adhesive such as gasket glue and the like? I don't think so but just checking as its the first time and the bible ( mini work shop manual) didn't say...that I could see.
DC
 Post subject: Re: gasket questions.
PostPosted: Thu Feb 05, 2009 12:36 pm
Tomboss Breweros
[quote="floss"]
Wipe surfaces with a rag dipped in petrol
[quote]
I like to use permatex red silicone. Its good stuff. Dont put heaps on because most will squeeze out.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Feb 05, 2009 1:29 pm
Like Tombo says, the wipe clean is essential but I prefer to use metho.
The gasket remover spray is good stuff too, makes scraping easier.
PostPosted: Thu Feb 05, 2009 1:49 pm
i meant to add that to my list... DAMN! :)
so red silicone all gaskets? just a smear?
PostPosted: Thu Feb 05, 2009 1:55 pm
Yes , just a smear , if you put too much on it will bulge out either side of the join and in some cases chunks of it can become a foreign object floating around in the oil .
PostPosted: Thu Feb 05, 2009 4:42 pm
hey guys,
Is this the stuff?
http://www.permatex.com/images/DisplayI ... /81160.jpg
PostPosted: Thu Feb 05, 2009 4:48 pm
Tomboss Breweros
couldnt see your pic so here you go.
Just a smear, what squeezes out isn't doing anything.
P.s. the packaging has changed, i couldnt find a more recent picture.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Feb 05, 2009 4:54 pm
I'm Bert , where's Ernie
get it from your local supercheap :wink:
if you want i'll take a photo tonight of what the packaging looks like now for you?
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Thu Feb 05, 2009 5:12 pm
Don't use silicone. It will create more problems in the long term. When silicone gets into an oil gallery or even when it fills a blind hole it can damage an engine.
Use a real gasket cement like Permatex No3 (or Loctite Aviation Gasket Cement)
PostPosted: Thu Feb 05, 2009 6:23 pm
Spot on Morris100
This would have been my exact answer too.
Dave
PostPosted: Thu Feb 05, 2009 6:27 pm
The Permatex in the pic above is now branded `Loctite'.
I used it for ages, but for the last 5 years I've used Loctite 515 Master Gasket instead. Unlike the Permatex it will never let go, it is designed to replace gaskets.
I don't use diff side cover gaskets now, the current ones are too thick and need a big pile of shims. Just a smear of Loctite 515. :wink:
PostPosted: Thu Feb 05, 2009 6:29 pm
Please don't use the Red Form-a-gasket silicone stuff!
Please think about the next guy that has to remove the gasket! Give the gasket a light smear of petroleum jelly and she'll be good as gold..... Well it worked on my car.
PostPosted: Thu Feb 05, 2009 6:31 pm
If you use the stuff that I recommended you can always pull it apart. :wink:
PostPosted: Thu Feb 05, 2009 6:55 pm
Hey guys,
Thanks for all of your help. I might get me some of the loctite 515. Is this easy to find? Where i work on my car they have repco, supercheap and autobarn so it should be ok to find in one of them i am guessing.
Thanks again, you all are so helpful for a newb like me.
D
PostPosted: Thu Feb 05, 2009 6:59 pm
Bearing shops stock it, & sell it cheaper than most other places. :wink:
Users browsing this forum: No registered users and 116 guests
