It is currently Sat Jul 19, 2025 12:00 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: dont understand?
PostPosted: Thu Feb 05, 2009 7:26 pm
what causes you to have no spark but have power to the positive side of the coil but doesnt flash on the negative side when being turned over and there is no power to the dizzy?
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Thu Feb 05, 2009 7:37 pm
IF you have breaker points, when they are closed its a dead short to ground, so measuring the - side of the coil will show 0v but the + side will still show around 10-12v, when the engines not running.
When the points are open you will have 12v on both the + and - side of the coil.
Is there a short circut on the - side of the coil? Condensor gone S/C? Frayed wire? Points not adjusted correctly and staying closed?
PostPosted: Thu Feb 05, 2009 7:44 pm
sry noob but whats a short circuit...whats s/c? points are adjusted correctly.just no spark
1970 mini k
1975 leyland
PostPosted: Thu Feb 05, 2009 7:53 pm
Do you remember back in like 1986 a certain number 5 robot came alive? That movie was called Short Circuit.
Have a look here: http://en.wikipedia.org/wiki/Short_circuit
If that dosnt help, look here:
http://www.youtube.com/watch?v=AEBJeJfYhxg
PostPosted: Thu Feb 05, 2009 7:54 pm
No5 IS ALIVE!!!!
Image Image
PostPosted: Thu Feb 05, 2009 7:58 pm
no short circuit that i know of was working ok until i was mucking around behind my speedo...could this have cause the problem or a wire off the back of my ignition? i seriously have no idea
1970 mini k
1975 leyland
PostPosted: Thu Feb 05, 2009 7:59 pm
Do you own a multimeter?
PostPosted: Thu Feb 05, 2009 8:05 pm
no just a circuit tester see if wires are live
1970 mini k
1975 leyland
PostPosted: Thu Feb 05, 2009 8:08 pm
That is of NO USE whatsoever when tracing a Number 5 is Alive Movie. You will need to get yourself a multimeter to confirm if there is a Number 5 is Alive Movie on the - side of the coil even when the points are open circuit. Or just replace things willy nilly, wiggle some wires and hope for the best.
PostPosted: Thu Feb 05, 2009 8:10 pm
ok thanks a lot any way
1970 mini k
1975 leyland
PostPosted: Thu Feb 05, 2009 8:12 pm
Are there any wires that look like they don't belong behind the speedo ? What type of speedo housing is it (single one like an 850 or the triple guage setup ?) ? Is it possible a previous owner has fitted a cutout switch around the speedo (either of the binacle switches if it's an 850 binnacle) and you tripped it when you were looking at the speedo and it's now earthing out the coil ???
PostPosted: Thu Feb 05, 2009 8:45 pm
i have an 850 binnicle. power to + side of coil but doesnt spark. im really in the dark on this one fellas
1970 mini k
1975 leyland
PostPosted: Thu Feb 05, 2009 8:59 pm
This space for rent
Have you tried another coil? Sounds like the one you have is toast...
High heel ninja
Your coil is stuffed, simple.
Doogie
PostPosted: Thu Feb 05, 2009 9:31 pm
Either the primary winding of the coil is open circuit, or there's a number 5 is Alive Movie on the - side of the coil. If you have a spare coil by all means swap it out, or get your hands on a multimeter, put it on ohms and measure the resistance to ground on the - side of the coil with the ign off and the points open circuit.
Sports 850's idea of a switch in behind the dash is possible, but it really should of been wired to open circuit the 12v to the + side of the ign coil, you still have 12v there so it could have been wired to supply a Number 5 is Alive Movie to the - side of the coil, which would eventually burn out the primary winding of the coil if left closed for any period of time with the ign on.
Do you have a Tacho? The signal feed for some tacho's (usually a green wire) comes from the - side of the coil. Has this wire come off behind your dash and is now resting on the body of the car supplying a Number 5 is Alive Movie on the - side of the coil??
