It is currently Thu Aug 14, 2025 11:00 pm
PostPosted: Sat Feb 14, 2009 5:18 pm
has any one got this combo has anyone got twin 1 3/4 in SU's on a 1275 if so how does it go what needles
have just ordered a set of twin 1 3/4
Ruling the bends and bending the rules since 1959
PostPosted: Sat Feb 14, 2009 5:36 pm
I ve run twin 1&3/4 carbs on my big bore donks for years, love em
I would just shove some OA6 needles & a pair of red springs in there for starters & go from there
it all depends on so many other variables as to what you may end up with on your particular engine,,, but the OA6s & reds will get you going without a hic-up & will be all wonderful to start with
 Post subject: j
PostPosted: Sat Feb 14, 2009 6:08 pm
I run RR needles with red springs... Think i selected them as that is what was sudgested in vizards book..
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Sat Feb 14, 2009 9:40 pm
I use 13/4 SU's on my 1360 which is in a fairly high state of tune.
I really couldn't recomend them on a stocker or even a mild motor though.
Red springs and KW needles work for me.
As matt says OA6 is a great starting point!
Dave
PostPosted: Sat Feb 14, 2009 9:43 pm
each piston in the engine only sees one carb anyway,,, so a stock 1275 running around on a single 1&3/4 is quite fine,,, then twins is just the same only with less manifold restriction
PostPosted: Mon Feb 16, 2009 5:51 pm
this a hijack so i appolgise in advance
twin 1.5 Su with a re13 cam
Needles would be
Ta in advance
PostPosted: Mon Feb 16, 2009 5:54 pm
Needles would be
Ta in advance
#6 worked for me in Barney, 1293cc, twin HS4s, cam was a Wade 104 with 1.5 rockers (so similar lift and timing to an RE13 and stock rockers).
 Post subject: Re: j
PostPosted: Mon Feb 16, 2009 9:45 pm
Did the same-but also got it set up on a dyno.
Also just as important is your inlet manifold and filter set-up.
I'm running with K&N Filters now with Maniflow manifold setup for 1 3/4.
Users browsing this forum: Barkfast and 271 guests
