It is currently Mon Jul 28, 2025 3:27 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 27, 2009 11:52 am
Take Dremel, relieve the block not the impeller.
PostPosted: Fri Feb 27, 2009 4:26 pm
and its all good?
PostPosted: Fri Feb 27, 2009 4:33 pm
Yep, they only just touch the casting, and not always.
PostPosted: Fri Feb 27, 2009 4:34 pm
Would a thicker gasket help?
David L
PostPosted: Fri Feb 27, 2009 4:36 pm
Too thick and it'll put the pulleys out of alignment .
PostPosted: Fri Feb 27, 2009 4:42 pm
wouldnt that screw over the water pump quickely?
PostPosted: Fri Feb 27, 2009 6:04 pm
If it touches it won't turn. So no worky. :lol:
Bolt it in, spin it, often there's no problem. If there is, see where it's touching and just grind or file the block there until it misses.
PostPosted: Fri Feb 27, 2009 6:24 pm
i thought you were talking about after you cut it to size-
Users browsing this forum: Bing [Bot] and 87 guests
