It is currently Mon Jul 28, 2025 8:12 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 27, 2009 2:45 pm
Or a blasting cabinet with an improvised scrubber on the exhaust
The 850 Man
PostPosted: Fri Feb 27, 2009 6:25 pm
Bubbacluby wrote:
I have been using De-ox gel, made/distributed by the same people that do POR-15.
Gets expensive though, $50ish per kg and im on to my 2nd one and may need another one (i had LOTS of rust), makes me think maybe i should have sandblasted, oh well
Brenton
benoz wrote:
I have about 1/2 a square metre to do, heavy surface rust (very little pitting) is this stuff the go?
yeah this stuff is the go it works brilliantly and 1kg will be heaps... ( i found the hardest bit is getting into the roof guters - but it gets there eventually). You may need to do it 2 or 3 times but works well ( i would say it would be pitted slightly after cleaned - i was surprised how bad mine was/is after it had been cleaned)
PostPosted: Fri Feb 27, 2009 8:50 pm
I met an old french miner once who was dying of silicosis, worst thing I've ever seen.
That aside thanks all! Two suppliers of abrasives and a chemical solution - time to decide which to use now!
Noli Illegitimi Carborundum
Users browsing this forum: Bing [Bot] and 79 guests
