It is currently Sat Jul 19, 2025 2:06 am
PostPosted: Sat Mar 07, 2009 5:25 pm
short branch extractors into 17/8th straight through with a hotdog in the middle sounds good. :D
PostPosted: Sat Mar 07, 2009 6:11 pm
Mick wrote:
BALLISTIC wrote:
Maniflow LCB extractors into either a 1 3/4" or 2" pipe to a "hot dog" 1 3/4 or 2" exit.......sounds quite good i think and works very well! stainless is nice but it depends on your budget.
The chinese copies of the maniflow are very nice as well if you want to save a few dollars.
Are they the same `quality'- ie. are the flanges bent like on all the Maniflow ones? :P A pity they never have made them flat after the welding distorts them.:x
I've run two sets now and vouch that they are great value. The ends are cast steel and nicely welded onto the pipe. No sealing issues at all, and MASSIVE ports as well. They are three piece and come with the steel clamps around each and every join. Center pipe is a larger gauge than the two side pipes. They keep a nice finish over time as well. Approx 220 - 245 depending where you go.
The only down side I have noticed is that the massive center flange needs to be ground down a little on the top to clear twin SU cross pipes. It would be no problem on just about any other manifold. Saying that, it only took two minutes with a grinder before fitting the manifold onto the engine. Maniflows look to have the same problem as well.
My mileage isn't as high as some, so anyone who's had any cracking or other issues with these pipes please speak up before I send someone down the tube :) My view is that they seem very good for the money. They make a nice noise with 1 /34" and a side exit RC40. Ask Davo111 :)
PostPosted: Sat Mar 07, 2009 6:29 pm
OK, I am speaking up! Where do you get 'em????
PostPosted: Sat Mar 07, 2009 6:39 pm
Any of the usual mini culprits sell them. I think they call them simply Maniflow copies.
PostPosted: Sat Mar 07, 2009 8:11 pm
this is what I put on Kermy. It was a stocky, but dad made this exhaust for me years ago. It starts out as standard mini exhaust manifold, gets gradually thicker thill its bout 2 inches, then just into a huge muffler at the back with twin pipes. Sits under nicely, is quite loud and resonating as you accelarate but when cruising, no noise! perfect for the highway. Cost me a slab of bundys for my dads time and all his "bitsa's" in the shed.
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Sat Mar 07, 2009 11:11 pm
last year i bought a exhaust system for my hot 1100
1100 020 ported head deshrounded
kent 276 cam
exhaust system was maniflow lcb extractors 2" WITH RC40
put it on my 998 a+ and had low backpressure problems resaulting in acceleration lag
i changed it yesterday, left the same extractors but changed the pipe to a straight through 1.3/4" with hot dog and unknown muffler. sounds 10x better heaps louder and has no lag and tones more power. the rite system really does make a diffference.
PostPosted: Sun Mar 08, 2009 12:54 pm
niceboy1275 wrote:
whats with the two locks?
PostPosted: Sun Mar 08, 2009 12:57 pm
2nd lock is an alarm system.
PostPosted: Sun Mar 08, 2009 12:59 pm
fair enough
 Post subject: Exhaust system
PostPosted: Tue Mar 10, 2009 1:06 pm
hey thanks for all the help people sounds like the 1 3/4 straight through with the RC40 is the way to go
once again thanks for the help
PostPosted: Tue Mar 10, 2009 2:08 pm
ahhh.... what size engine are you running? What carby(s), head and cam?
If it's only a standardish small bore (848, 998, maybe even 1098) then some of these suggestions may not be the best for your car because they may not have enough back pressure. A LCB with an 1.5 or 1.25 inch pipe may give more power and sound just as good on a small engine.
 Post subject: exhaust system
PostPosted: Tue Mar 10, 2009 4:23 pm
Hi well i have a clubman S 998 single carby and thats about all i know about it
PostPosted: Tue Mar 10, 2009 4:29 pm
On a mostly standard smallbore, 3 in to 1 extractors and 1.5" pipe would be best, but i'd recomend going LCB's and 1.75" as i'm sure the modification wont be limited to the exhaust?? Correct?
PostPosted: Tue Mar 10, 2009 4:41 pm
yeah i think your right about this being one of the first of many mods
just as long as dad doesn't know how much its costing me LOL :D
PostPosted: Tue Mar 10, 2009 6:09 pm
I think from your photos the rust is more important than the exhaust system at the moment, unless their before photos., the other point is be careful how the exhaust system is mounted, dont throw away the original system use it as a template for the bends, try to follow the original bends and mounts, if its mounted to low you could have it ripped out, mounted to close to the floor and you could have a fire ,I,m not joking ! . Now I am speaking like your going to make it , but you need as much information as possible before you go and hand over a wad of cash and say make this.
