It is currently Thu Jun 26, 2025 8:00 am
 Post subject: Highbeam only?
PostPosted: Mon Mar 16, 2009 3:49 pm
Milatsmadmini
My moke is goin for a blue slip next monday arvo everything is going lovely until i try to turn the lights on.... i can only get high beam and parkers no normal beam.... can anyone give suggestions?
PostPosted: Mon Mar 16, 2009 4:11 pm
make sure the low beam circuit has juice. Trace it back - mine did them same - it was broken in the low beam to ignition circuit.
PostPosted: Mon Mar 16, 2009 4:13 pm
I've had the indicator assembly wear out and the low beam terminal had melted back into the plastic . Look for melted plastic in the area of the contacts on the indicator stalk as well as trace back the wiring as BIAM suggested .
PostPosted: Mon Mar 16, 2009 4:15 pm
I didn't have high beam the other day.... I'd accidentally yanked the main wire out of the connector where it splits to the 2 lights behind the grille... it's usually something simple
PostPosted: Mon Mar 16, 2009 4:18 pm
ginger ninja
ginger ninja
I hope you dont mind me adding a question to your thread Matt :oops:
But Cherry doesnt have any reverse lights? I have been told they are twin filament bulbs with the indicators and my indicators work fine :? Would it be wiring or a switch or something like that?
sports850 wrote:
PostPosted: Mon Mar 16, 2009 4:23 pm
could be gearbox switch, or wiring or bulb - so any of it really
PostPosted: Mon Mar 16, 2009 4:34 pm
did you pass?
Talk is Cheap because Supply Exceeds Demand
mattsmadmini wrote:
you've got awesome norbles
I'm Bert , where's Ernie
exactly the same to mine, cept my blinkers dont light up when she goes into reverse, always passed rego checks, so its pretty sweet for me, it is a 73 though.
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
 Post subject: moke lights
PostPosted: Mon Mar 16, 2009 4:38 pm
My moke had 'flakey' headlights before, they would work fine then (just when it was real dark) they would fail, had some problems with the connector between the indicator harness and main wire harness, but still played up sometimes. Ended up the earth wire was broken at the clip (plastic holding it in place) at the solinoid mouting bolt.
BTW that reminded me that I had upgraded the high beam with 100 watt halogens, relay and new positive wires, but neglected the earth wire....
Cool stuff!!
 Post subject: Re: Highbeam only?
PostPosted: Mon Mar 16, 2009 7:29 pm
Is it realy Cold??? :lol:
PostPosted: Mon Mar 16, 2009 7:39 pm
madmatt, it could be the high beam switch itself. If that's dumb, don't bother saying so.
PostPosted: Mon Mar 16, 2009 9:23 pm
Milatsmadmini
cass, next week darling...
bam, nah, all was working last week, (when the horn wasnt working...) now that the horn is working again, the normal beams arent lol, ive traced back and cant seem to find any wiring issues.... need sleep, have a better crack at it in the morning... good ol' lucas wiring... maybe i need some smoke? :roll:
PostPosted: Mon Mar 16, 2009 9:41 pm
Milatsmadmini
hahaha just found a loose connector.... got both beams! for 2 minutes... now only low beam lol :lol:
PostPosted: Tue Mar 17, 2009 7:24 am
Resident Test Pilot
whenever this has happened with "morris" its the junction of the wires just behind the grille, in the middle.
I just move it around a bit and push at the wires and hey presto ! all good.
PostPosted: Tue Mar 17, 2009 9:41 am
yes, good ol' lucas wiring, works perfectly until someone mucks it up!!! :P :lol:
Users browsing this forum: No registered users and 199 guests
