It is currently Tue Jul 22, 2025 7:36 pm
PostPosted: Tue Jul 15, 2008 5:37 pm
[quote="sports850"] :lol: Now you see why I didn't write it out myself , there's all the little things you do automatically but miss when you write it all out .[quote]
I'll see if I can remember to list all the steps when I pull out the engine in a month or so. The we'll have a how to - specifically for a Clubman but can be adapated for a Roundy.
-Alan
PostPosted: Tue Jul 15, 2008 5:39 pm
Here's my 2 cents worth.........before removing the bonnet, mark where the edges of the hinges are. That way, the bonnet will go back in the same position when the job's finished :)
Hooroo
Rod Image
PostPosted: Tue Mar 17, 2009 11:14 pm
Do you need to drain the oil from the sump at all? Or will it stay in the sump once the engine is lifted out? The rusted out engine I'm taking out (this week) looks like it has the sump plug well & truly stripped and refuses to budge. If I DO need to drain the oil, I'm seriously contemplating drilling a hole in the side of the sump to do it.
-Alan
PostPosted: Tue Mar 17, 2009 11:21 pm
Tomboss Breweros
Don't drill a hole, someone might want that part.
If you leave the inner cv cups in the gearbox you can leave the oil in.
It is possible to get the driveshafts out of the inner cv cups without dealing with the suspension but it's a hassle to put back.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Mar 18, 2009 12:18 am
If its a rover.......The air cleaner, battery, I could make a list but its going to be long! :roll: Smarty and I just done it and it takes a while i'll put a thread together one day.
You start off here
Take things off until you get to here
Put everything (bolts, brackets etc) in sandwich bags and white clearly on them and MOST importantly take lots of photos so you know how bits go back together! :) Get a book and we had a really good DVD by by bill sollis I think on step by step building a motor and gear box, it was really handy having something to watch.
Good luck
PostPosted: Wed Mar 18, 2009 1:38 am
mmmmmmmm im no expert , ( had about 10 beer s s o fa r and weel this poped up LOL.
Doogie's guide to removing a mini engine
IN THE HOW TOO SECTION.
^^ caps r just so i can rwead it ..
GL
HopED i helped
PostPosted: Wed Mar 18, 2009 6:21 am
Doogie did do a write up a few years back - I thought it was made into a sticky or how to?
KB
PostPosted: Wed Mar 18, 2009 6:30 am
It was and is third or fourth down the page in the how to section , http://www.ausmini.com/forums/viewtopic.php?t=45377
PostPosted: Wed Mar 18, 2009 7:28 am
Park it at Airport West :wink:
PostPosted: Wed Mar 18, 2009 12:17 pm
Go out and buy yourself a good quality scissor type ball joint splitter. Your going to need it to refit the pot joints or is it to remove them ??
Either way its needed.
Again - put the front of the car up on jack stands - nothing else - and give the whole car a shake before attempt to undo anything - including wheels. If it falls off the jack stands while you are underneath it WILL kill you. So make sure its not going to fall by shaking it before you get under it.
Mike
PostPosted: Thu Mar 19, 2009 3:31 pm
I split the bottom ball joints and pulled the hubs back to release them from the inner pots. Balls still went everywhere but wasn't too bad. I seems I had much better chance of removing the extractors after un-doing the top engine mounts (bottom still connected) and rocking the donk forward after un-doing all manifold nuts.
Any advice on the rod change box rolled pin? Took me half a day to remove! Smashing it with a drift in an upwards direction would then foul the diff housing???tried all manner of gears and neutral??? ended up cutting the upwards protrusion with a dremel cut of disc and kept pushing it up till it came out... had me fully stumped?
PostPosted: Thu Mar 19, 2009 4:10 pm
Doing whilst in reverse gear normally gives enough clearance to push it out with a pin punch of the right size. Hitting the pin itself just flares the end and makes it more difficult to get out.
KB
