It is currently Tue Jul 01, 2025 1:34 am
PostPosted: Tue Feb 22, 2005 10:48 pm
Aussie Racks have 2.5 turns lock to lock, Pommie is 2.7 turns..
Sportspack coopers came with a shortened rack...possibly a 2.5 rack?
Difference between the two is also the steering arms...
PostPosted: Wed Feb 23, 2005 12:04 am
The last thing you need to worry about is having the wheels rub on the inner guard. When they rub on the outside, thats when you need to take action.
My Mazda doesnt need a handbrake, I just turn full lock and the car wont budge.
You'll never turn full lock while driving at speed anyway.
PostPosted: Wed Feb 23, 2005 12:08 am
You do if you get her sideways and you need to do full oppy lock :shock: :lol:
PostPosted: Wed Feb 23, 2005 12:11 am
Image of course
PostPosted: Wed Feb 23, 2005 5:51 am
The "standard" rack for UK Minis is the same as the aussie ones (turns lock-to-lock and turning circle).
--- BUT ---
If it was a later Cooper with the Sports Pack option (wider arches and 13x6 rims instead of the 12's) then it was fitted with a modified rack that limited the turning circle so that the inside rear corner of the tyre didn't rub on the inner guard. However the Aussie Performance 13x7 Supellites that we are running have a "deeper dish" offset that makes the tyre sit further out and they don't have this problem with the standard rack.
HTH Mr Mutant (John)
mutant mini 1380cc '73 UK imp-Chroma Lusion-leather interior-8 x 300W Diamond Audio Dual Voice Coil 8" subs, Phoenix Gold 4 chnl amp, Pioneer 7550 DVD, 2x Phoenix Gold A1.800d MonoBlock Amp, Focal Utopia splits, 14" chrome rims 195/40/14 tyres
PostPosted: Wed Feb 23, 2005 6:25 am
John, UK Mk2 rack is 2.7 turns and gives tighter turning circle, but uses MK2 arms. Oz rack was 2.25 turns
PostPosted: Wed Feb 23, 2005 7:04 am
I wsn't referring to mutant in my post I was referring to my Rover Cooper.
PostPosted: Mon Jul 25, 2005 9:50 am
hey fellas, i currently run 10x4.5 mini mags jelly bean type. but i wanna move up to a 13x7 or 13x8. Pretty much as high as u can go. Someone mentioned if u had spaced drums on the front? i have spaced drums, so im guessing i should be ok with 13x7 or 13x8s fitting correctly. If u have to cut, its just the wheel arch right?
peace
Image Image
PostPosted: Tue Jul 26, 2005 1:00 pm
i dont know if this seems like a stupid question but what are the lug hole spacing measurment on minis i could just go and look it up in the gegorys manual but then i cant find it
PostPosted: Tue Jul 26, 2005 1:10 pm
Stud size on a Mini is 3/8" UNF, 4 holes on a PCD of 101.6mm (4")
