It is currently Tue Jul 22, 2025 3:32 pm
 Post subject: su needles
PostPosted: Thu Mar 19, 2009 12:29 am
hey gang!
getting the mini tuned, but the needle is wrong.
its a 998 with extractors 1 1/2 " su unsure of internal work, but seems lumpier than standard at idle.
at teh moment it has an AAC needle in it hich has a flat spot about half throttle. and generally runs poor.
what are other peoples opinions/ experiences, what do you think i should use, and where can i find one!
cheers jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Mar 19, 2009 8:36 am
I would have the tuner modify the needle to suit. I just had Greig at mini classic do this and the car is running beutifully. Who do you have tuning your car?
PostPosted: Thu Mar 19, 2009 9:15 am
ive got a A+ with extractors and 1 1/2 SU supposedly the factory needle is ADE and im running ADF as there was a flat spot around 2k rpm. it isnt tuned properly though
PostPosted: Thu Mar 19, 2009 9:47 am
flat spots at 2k rpm are often caused by empty dashpots - check that first
PostPosted: Thu Mar 19, 2009 10:05 am
dashpot has fluid in it.(sewing machine fluid, was having the same problem with ATF)
with the ADF needle the flat spot isnt noticeable.
PostPosted: Thu Mar 19, 2009 10:08 am
being tuned by a local, hes been playing with customers su's for years, but doesnt have any needles lying around.
just thought i would check to see what people suggest to get it closer to ballpark, so less modifiing!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sun Mar 22, 2009 10:30 am
any other suggestions team!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sun Mar 22, 2009 6:38 pm
OK, I'll stick my kneck out!
Blue spring
E3 Needle
Will work!!!
Dave
PostPosted: Mon Mar 23, 2009 12:02 pm
where do you guys get your needles from?
can find a number for midel, and the links seem to be broken from google!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Mar 23, 2009 12:06 pm
telephone works wonders - ask them about converting from a springy needle too
PostPosted: Mon Mar 23, 2009 12:10 pm
that meant to say cant find a number for midel, sorry
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Mar 23, 2009 12:12 pm
ahh, look in here, I found out about this listing the other day -> http://www.ausmini.com/forums/viewtopic.php?t=10543
PostPosted: Mon Mar 23, 2009 12:14 pm
thanks simon!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Mar 23, 2009 4:00 pm
I've got a box of them here Jamie.
your welcome to come have a look and a borrow.
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Mon Mar 23, 2009 10:49 pm
thanks steve, i have ordered the suggested one from sumidel, if that doesent work, ill come and visit!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Users browsing this forum: 68+86auto and 87 guests
