It is currently Wed Jul 23, 2025 9:29 am
PostPosted: Tue Mar 31, 2009 5:17 am
I've just had quite a battle with a 1275 flywheel that had welded itself to the crankshaft taper. It came in the end (quite softly) with a 20 ton hydraulic puller. I always bolt a row of heavy penny washers around the bellhousing bolts, the flywheel can't go anywhere that way.
Al
PostPosted: Tue Mar 31, 2009 4:13 pm
TheMiniMan wrote:
tips to removing a flywheell you ask???
"""Hydraulic puller""
I used to borrow a Churchill Hydraulic puller off my mate. But I moved away and now the puller is 250km away. :cry:
I think that there would be one nearby that I could borrow if I need it, the retired service manager from the old Goulburn BMC/Leyland dealer lives nearby and he has all the special tools! :D
I just use a normal threaded puller and it works even though it needs a lot more effort to work. But using the heat gun on the flywheel hub seems to make the threaded puller work as good as a hydraulic puller. :D
Another reason for not hitting a puller/flywheel/crank with a hammer is the damage that it does to the thrust bearings.
PostPosted: Tue Mar 31, 2009 6:10 pm
Hydraulic pullers are the bees knees. I have access to 2 which makes life so very easy indeed.
PostPosted: Tue Mar 31, 2009 6:40 pm
This is what i use. the best tool for the job but now NLA. "extra long flywheel bolt" (simon k) came out of an early 850 with the little ended crank
as the sticker says - dont bash with hammer.
Have a Nice Day.
PostPosted: Tue Mar 31, 2009 6:47 pm
They spelt cockhead wrong... but the message is right!:P
PostPosted: Tue Mar 31, 2009 6:49 pm
Well, would you hit yours with a hammer? (actually Gadgets would)
PostPosted: Tue Mar 31, 2009 7:13 pm
Had any luck Kenno?
PostPosted: Tue Mar 31, 2009 7:14 pm
ah hah... thank you :D
PostPosted: Tue Mar 31, 2009 7:32 pm
Simon,,, i think the autospastics got a long flywheel bolt too,,, but i vaguely remember that the thread isn`t cut all the way up the bolt...hhhmmm,,,, gettting dads dementiure/alszhiemers more & more these days,,, where are we btw? & who are all you people ? & what are you all doing in my fridge anyway???
PostPosted: Tue Mar 31, 2009 11:02 pm
Join the club. It's a hell of a way to go.
www.minisprintgt.com
PostPosted: Tue Mar 31, 2009 11:03 pm
ahhh its ok,,, you get to meet new people evryday :-)
PostPosted: Wed Apr 01, 2009 7:58 pm
I have always wanted to build this puller, but have never got around to it as i also have the factory churchill puller (paid $20.00 for it from an old BMC mechanic who brought it when he did his apprentship and i got talking to him and he was moving to an retirement home so wanted to go to some one who would use it, that would be 25 years ago) and Its never leaves my workshop unless its in my tool box.
http://www.drjing.com/Mini/TechFiles/Hy ... Puller.htm
PostPosted: Wed Apr 01, 2009 8:09 pm
Drinking your Beer, what else would we be in there for :?: :D
Dicko
