It is currently Wed Jul 23, 2025 9:37 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Wed Apr 01, 2009 9:09 pm
A machine is only as good as it's operator. :) :)
I just love the diamond impregnated ceramic tips. I use them to machine down hardened surfaces that needle roller brgs run on. Do not chip them, they are around $250 each.[definately not chinese crap.]
You can use them on any lathe,slow speed and feed and plenty of soluable oil
www.minisprintgt.com
PostPosted: Wed Apr 01, 2009 9:20 pm
sitnlo62 wrote:
Did you think it was hard material?
Maybe the one I did was an exception it was as hard as hell!
Dave
It was tough, not that hard. Slow and easy, with some cutting oilz... :wink:
PostPosted: Wed Apr 01, 2009 9:21 pm
True that :lol:
Dave
PostPosted: Wed Apr 01, 2009 9:24 pm
True that :lol:
Dave
Hey Dave do you need a cheap milling attachment for your Myford?
I have one, hardly used, not being used any more (I bought a mill).
It bolts on where the toolpost goes. :wink:
PostPosted: Wed Apr 01, 2009 9:31 pm
No thanks Kevin, Probably a little out of my league :)
Check my profile :wink:
Dave
PostPosted: Wed Apr 01, 2009 9:42 pm
I don't need one thanks, I got a hafco mill/drill and a hafco lathe. It's the only new machine I could find that was set-up for imperial . Just can not get used to this new fangled metric system. young steve has bought him-self a small hercus lathe so I will ask him. I am teaching him machining :shock: Blind leading the blind
There are a few others on ausmini that have lathes, one of them might be interested.
PostPosted: Wed Apr 01, 2009 9:47 pm
Hey Wombat,If some one or your self can give me the dimensions that you need to machine the shaft to, let me know. I have a few spare shafts and I can machine one and send it to you
PostPosted: Wed Apr 01, 2009 9:59 pm
Vizard's "Tuning the A-series Engine" 3rd Ed page 470 Pretty picture but no diamensions.
Thanks for the offer - I've bagged it already to post with something I owe the Doc for past services.
David L
PostPosted: Thu Apr 02, 2009 7:11 am
The "hardness" of these spindles varies, no idea why. My machinist found this out recently when he did 3 for me, there was a notable difference between them. He does them in his lathe.
Steve
PostPosted: Thu Apr 02, 2009 7:52 am
Resident Haemorrhoid
Wombat You should of taken it to Tassie with you and dipped it into the water down there :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Apr 02, 2009 10:20 am
Cold enough to shrink anything :wink:
David L
PostPosted: Thu Apr 02, 2009 10:23 am
Thanks justminis, just confirms my thought that they must very in hardness!
Dave
PostPosted: Sat Apr 04, 2009 7:09 pm
OK Wombat,
to fit these +.100" GR flat top 1098 pistons (which don't have undercut skirts like normal 1098s) the dizzy driveshaft needs to be turned down to .350" diameter and relieved a bit at the top end radius.
GR usually sends a modified shaft up when people buy these pistons and get a block bored- but somehow you missed out.
When it gets here I'll take it to GR's and machine it. :wink:
PostPosted: Sat Apr 04, 2009 7:32 pm
Thanks Doc - glad it turned out to be something "simple"
David L
Users browsing this forum: Steam and 79 guests
