It is currently Tue Aug 19, 2025 5:55 pm
 Post subject: How tight ?
PostPosted: Mon Apr 13, 2009 5:13 pm
do you do the nuts (nyloc) on the rear subframe pins. I appear to be just squashing the rubber bushes and I imagine could eventually bottom out but is that right - there would be no play in the bushes then to give cusioning.
David L
PostPosted: Mon Apr 13, 2009 5:25 pm
They are supposed to be tight. The shoulder on the pin sets the compression of the rubber.
Same setup as front tiebar rubbers, really.
PostPosted: Mon Apr 13, 2009 5:27 pm
OK - back out to keep tightening after tea :roll:
David L
PostPosted: Mon Apr 13, 2009 6:42 pm
You've got the large washers for them right? It shouldn't be an issue if these washers are in there.
PostPosted: Mon Apr 13, 2009 6:47 pm
Yep
David L
Users browsing this forum: Sreedon and 78 guests
