It is currently Sat Aug 02, 2025 12:33 pm
 Post subject: Boring a 998
PostPosted: Thu Apr 16, 2009 9:31 am
Trying to compile some info on boring a 998.
1. How big can i go? (safely as its going to be used for hard race work)
2. Are the parts easy to come by? (pistons, valve springs, new keepers, new pushrods, rocker arms, camshaft, lifters, oil pump, timing set, cam bearings etc)
3. Is there anything i should be aware of when boring out a 998 that is different to the usual? (usual to me being old holden 202)
PostPosted: Thu Apr 16, 2009 10:23 am
all the parts you will need are "real" easy to come by.
As far as a rebore is concerned your limiting factor is being able to find pistons.
100 thou over are the biggest "standard" Mini pistons you can get. Graham Russell sells em.
Since you are racing it I would stop at 100 thou for reliabiltys sake.
On a side note Matt Reid went 200 tho over and used bike pistons on a recent hand grenade he put together.
blokeinamoke wrote:
PostPosted: Thu Apr 16, 2009 11:27 am
An 1100 crank would be a good idea at the same time.
I think it would make your motor about an 1152cc I think, and if you're real serious you could pocket the block and use a 1275 head but probably not necessary.
There is a wealth of info on "big" 998 and 1100 Minis as many of the users on here are big fans on of the motors, maybe a search? (Although the search function is pretty useless on here, but sometimes can pull some good info).
PostPosted: Thu Apr 16, 2009 11:32 am
998 with a 1100 crank and 80thou o/s makes it a 1215cc
- 1962 Beige Delight club car, Rebuilding.
- Motorkana Special
- Minor Mishap, 1958 Morris Minor
-- Last ever Tea Lady at Longbridge--
 Post subject: Re: Boring a 998
PostPosted: Thu Apr 16, 2009 12:31 pm
This will probably be limited by the racing class you want to run in, check the rules before you start.
The 850 Man
PostPosted: Thu Apr 16, 2009 1:39 pm
Nope sorry, it's just not that big with +.080" ones. It's 1166cc.
+.100" GR or Hypatec pistons with an 1100 crank gets you 1188cc.
To get 1215cc takes a 68.0mm bore (Imp pistons or similar) and a 1098 crank. Hard to get GOOD Imp pistons now.
If boring a 998 with its std 76.2mm stroke crank, you can get +.120" pistons (1095cc) from http://www.minisport.com.au/prod1094.htm - but don't expect more power than with +.100" ones (1062cc) as cylinder walls are getting a bit thin.
PostPosted: Thu Apr 16, 2009 2:39 pm
any bigger than 803cc and you are just Bragging
- Motorkana Special
PostPosted: Thu Apr 16, 2009 4:37 pm
Thanks for the replies guys! Loads of knowledge in these here forums, I'll be full of questions in a few months time. Anyone reading running a "big" 998?
Might be easier than i thought to lay hands on pistons - I drive past MiniSport twice daily to and from work :D
Adding an 1100 crank was mentioned a few times, are they expensive/hard to find?
albino235: Thanks for the heads up, though running two engines puts me in a class of my own.
Once again, thanks for you help, advice and wisdom.
-Matt
PostPosted: Thu Apr 16, 2009 6:39 pm
nah not hard if you need one i have one you can have.
needs a regrind though.
Users browsing this forum: ken@miniauto and 88 guests
