It is currently Sun Jun 29, 2025 12:25 pm
Post new topic Reply to topic  [ 132 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
PostPosted: Sun Jan 30, 2005 6:29 am
1310/71 wrote:
Mine's a std one that's been chromed (bling Bling 8) )
So we'll have to linish my set fairly well. :)
Just oval the 2 holes in top of cover forward by 1mm or so, then push the cover back. 8)
PostPosted: Sun Feb 13, 2005 7:07 pm
Here's the Corolla rockers mounted on Barney's 1293 motor. Sorry about the lighting.. :roll:
Check the valve lift.... cam is a Tighe or Wade 104, normally has only around .320" valve lift with stock rockers. 8)
Last edited by drmini in aust on Thu Feb 19, 2009 6:20 pm, edited 2 times in total.
PostPosted: Sun Feb 20, 2005 8:15 pm
Hi Dr Mini
any chance of a picture of the push rod end of the head
thanks
KIWIINWGTN
PostPosted: Sun Feb 20, 2005 8:17 pm
Far out the valves come RIGHT up.
Love the colour on the motor too.
PostPosted: Mon Feb 21, 2005 9:53 pm
kiwiinwgtn wrote:
Hi Dr Mini
thanks
KIWIINWGTN
Bit dark out there- I'll take a pic tomorrow. :wink:
PostPosted: Wed Feb 23, 2005 6:25 am
Couple of pics of Corolla rockers-
Note the end-on view in pic 2 is an optical illusion- these rockers DO clear the alloy cover! 8)
No... I'm not using the gasket shown in pics... :lol:
Last edited by drmini in aust on Mon Jul 11, 2005 7:34 pm, edited 1 time in total.
PostPosted: Wed Feb 23, 2005 8:35 pm
Thanks for the pictures
owe you a beer should you ever get to NZ
Kiwiinwgtn
PostPosted: Fri Feb 25, 2005 8:48 pm
Started the bastard today, man it sounds cammy at idle with this Tighe/Wade 104 cam! Not driven it yet, tomorrow is the day..... :P
Only running a single HS4 off the old 998/1098, until I overhaul and Bling! the twin HS4s. :wink:
Last edited by drmini in aust on Thu Feb 19, 2009 6:21 pm, edited 1 time in total.
PostPosted: Mon Jun 20, 2005 1:15 am
So, any updates on this topic??? Happy with the outcome?
Is is safe for me to print page 1 off and send the details to a machinist for fabrication???
PostPosted: Mon Jun 20, 2005 7:42 am
SC,
Yep, the prototype set has been running now in Barney for months. No problems. Bushes are not wearing either.
BTW, these rocker bushes are made from LG2 bronze bar, I bought it from Bohler Steel.
I'm about to make a few more sets for people..
This time I'll make new rocker posts, out of 25x50 steel bar.
Details on p1 are still pretty correct, so go for it. 8)
Don't just turn the rocker posts around- they are too thin then when the holes are drilled out for the head studs. Not enough clamping area...
Make new ones- move the shaft holes back 4.0-4.1mm.
The rocker width needs to be reduced on the side where the oil hole is, by 0.140". Finished width is 0.625".
<edit> sizes updated. :wink:
Last edited by drmini in aust on Thu Feb 19, 2009 6:21 pm, edited 2 times in total.
PostPosted: Sat Mar 04, 2006 6:18 am
Making these new rocker posts from scratch is an awful lot of work, and they perform no better than a set of stock posts with the holes relocated.
So in future that's how I'm doing them, again. 8)
I've had my original set on Barney's 1293A+ now for over 12 months, they are going great. Good power to 7000 with the Tighe/Wade 104 cam and twin HS4s.
Last edited by drmini in aust on Thu Feb 19, 2009 6:22 pm, edited 1 time in total.
PostPosted: Mon Mar 06, 2006 9:36 am
www.karcraft.com.au
:wink:
Hey Doc-You you had any experience with Keith Dodd 1.5 Forged Rockers?
Thanks.
PostPosted: Mon Mar 06, 2006 10:21 am
Yes I've had a set on Ha-Ha for years.
Still going great. They do have a little more lift than the Corollas.
I'm running them in the 1360 with an RE282 cam, valve lift is about <edit> 0.492" inlet, 0.485" exhaust.
Last edited by drmini in aust on Mon Mar 06, 2006 2:12 pm, edited 1 time in total.
PostPosted: Mon Mar 06, 2006 1:46 pm
Thanks Doc'-Going to fit a set on the 1380.
I heard that they don't wear the rocker ball as fast as other 1.5
PostPosted: Sat Mar 11, 2006 3:06 pm
[img]http://i44.photobucket.com/albums/f46/dbr11k/100_0349.jpg
i found these on a clubman i just bought i think there roller tip[/img]
Users browsing this forum: No registered users and 25 guests
