It is currently Sat Jul 19, 2025 5:22 pm
PostPosted: Fri May 15, 2009 10:54 am
Does the choke cable need to be lengthened when relocating the carb onto the SC12 when using Ben's kit or does the standard length choke cable still fit?
PostPosted: Sun May 17, 2009 6:44 am
Anyone? I've got an old choke cable with a white knob that I really want to keep. A place called speedy cable can extend it for me but I need to know if teh standard mini choke cable length would be OK?
PostPosted: Sun May 17, 2009 9:03 am
The standard length should work OK the carby isn't moved far from the original spot just turned around.
4efte powered Clubman
supercharged 998 race car
PostPosted: Sun May 17, 2009 9:40 am
Thanks Ben
