It is currently Sun Aug 03, 2025 12:59 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Sun May 17, 2009 9:37 pm
5.8 litres would have it bubbling out of my gearstick inside the car!
PostPosted: Sun May 17, 2009 9:41 pm
Have u tried that already Mick :D
PostPosted: Sun May 17, 2009 9:45 pm
what is it with a spin on filter, as i'm about to try and change mine over to the spin on any tips, is it difficult for a Noob. Also can you put a pan under the car with out having to jack it up?
PostPosted: Sun May 17, 2009 9:49 pm
You will need a spin-on filter head gasket and filter, also shorter studs, or just use 3/8 UNC bolts like they do on A+ motors.
I put a brick on the driveway and drive my left front wheel up on it. Driveway faces downhill a bit so it then drains out good.
Drain tray fits under fine.
Last edited by drmini in aust on Sun May 17, 2009 9:50 pm, edited 1 time in total.
I run my car onto a a couple of blocks of wood to lift it enough to get the pan under the sump. It is easier than using a jack and stands.
But I do get the jack and stands out to grease the ball-joints and give the uni-joints and exhaust mounts an inspection.
I also give the underneath a go with a can of degreaser to keep it clean.
PostPosted: Sun May 17, 2009 11:37 pm
My owners Handbook says 8 1/2 pints (4.83 ltrs)
PostPosted: Mon May 18, 2009 7:13 am
Location: Burpengary,Brisbane Nth(the better side of Bribane)
Thanks for all the replies, I'm going to have to check my dipstick I think. To answer a few questions , It's a cartridge filter but I do have a spin on kit to fit on the next change. I get the KMX 6 Lt oil . Iv'e got a low profile floor jack to lift the motor , it only has to go up about 2 inches to get somthing under it to catch the oil.
https://t.me/pump_upp
PostPosted: Mon May 18, 2009 7:33 am
If you have an oil cooler fitted, that will take an extra 500ml.
Still doesn't make up the difference though.
