It is currently Sat Jul 19, 2025 4:37 pm
PostPosted: Tue May 19, 2009 9:37 pm
barely tougher than a potato crisp,,, more like a thick Pringle :-)
You can`t miss the ones that have been hardened too,,,, they are`nt shinny anymore, they go a grey-ish dull colour,,, steer clear of them
Edit,,, Oh & it`s not just that the front pulley comes loose & can wreak havoc on your fan blade,,, wrecking the crank key & possibly the crank in the process,,, but you will have a few pieces of old steel shim metal flinging around in your gearbox too :-)
Yummy tell your mummy :-)
PostPosted: Wed May 20, 2009 3:37 pm
OK gang, where's the cheapest place to get a new Romac balancer? (steel one will do me)
And, are they better for my peaky 1360 than getting an old one re-rubbered by Ross Tuffbond?
PostPosted: Wed May 20, 2009 3:46 pm
Romac are one of the very best balancers around (in my opinion) & JP bought them out but they have kept them as a seperate business
I`m buying a bundle for both myself & a few overseas customers soon if you`d like to tag along?
PostPosted: Wed May 20, 2009 4:22 pm
Just got my new alloy/steel one (ROMAC Part # 239SA)
Boy is it light, and shiney too 8)
Must be half the weight of the original, and excellent build quality.
PostPosted: Thu May 21, 2009 11:01 am
Weighed it, it's only 840g as opposed to the 1440g of the original.
That's a 42% weight saving, mostly at the outside :D
The bad part is, it won't fit onto the crank - too tight!
What should the larger diameter of the taper be on an original pulley?
The old one is 25.68mm, the new one is 25.18mm
Should I just linish the outer edge so I can at least get it started and then pull it on with a bolt?
PostPosted: Thu May 21, 2009 12:07 pm
It's wrong, or your measurements are.
Crank nose is 1.000" (25.4mm).
If smaller than this, I'd ring up and have a whinge to Romac...
PostPosted: Thu May 21, 2009 1:15 pm
1" was what I guessed it should be.
Using the calibrated digital vernier here at work I get:
- Old pulley 25.88 tapering to 25.44mm
- New pulley 25.38mm
The crank has a few marks on it, so I will just linish it the best I can & draw the new pulley on.
PostPosted: Sat May 23, 2009 3:33 pm
PM sent. :wink:
