It is currently Mon Aug 04, 2025 5:36 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Wed May 20, 2009 6:09 pm
Are they supposed to be screwed between the body and the headlight bucket?
Not the headlight retaining screw? Wouldnt that move them back?
Im here to learn!
PostPosted: Wed May 20, 2009 6:15 pm
Can you remove the chrome retaining ring and sit the clip under the rim and then sit the rim backover it so only the bit that attaches to the mesh is showing???
Same process as fitting eyelids, or headlight peaks???
PostPosted: Wed May 20, 2009 7:41 pm
Nah, something is not quite right there, they should be sitting a lot closer to the headlight, maybe try and sit the clips closer to the base of the chrome retaining ring ie; sit the bottom of the clip closer to the headlight bucket maybe and see how that looks, ( the base of the clip doesn't sit under the bucket does it ? The one's i have on mine are the sort that you take the retaining ring off and push the gaurd over the headlight then put the ring back on.
Colin
PostPosted: Wed May 20, 2009 7:51 pm
they sure as hell ain't for a mini. looks like someone got a chip scoop and found some clips.
Here are some pics of a pair of genuine ones. the mesh has it's own surround and is hinged on the headlight rim. The original BMC ones were stainless steel. There were some aftermarket one that were chromed. EH holdens had similar but the headlight rim was different where it mounted.
www.minisprintgt.com
PostPosted: Wed May 20, 2009 9:07 pm
Rover Cooper
I just got an email from the supplier and he thinks that they have been supplied with the wrong clips, :oops: now that would answer a lot of questions.
Mick called in on the way to the Geelong Dinner, and he agrees with me that the clips are not the right ones, they can be modified to fit, but you shouldn't really have to do that. :roll: :roll:
I will percevere because it is the right thing to do, so will keep all interested parties informed. :wink: :wink:
PostPosted: Wed May 20, 2009 9:13 pm
these are the way the new style headlight mesh thingys are made - fair few minis have them on, but the original style look better. Mine are originals, but don't hinge, I'd like some hinged ones...
PostPosted: Wed May 20, 2009 11:00 pm
well there you go Simon I have never seen that type before only the ones that I took pics of.
I know these are geniune BMC ones as they still had part sticker on them[very faded] There were two sets in the parts I got. One for the moke and one to sell and another set on one of the cars.
Mind you I think a small stone could still go thru and do some damage
PostPosted: Wed May 20, 2009 11:09 pm
There were two sets in the parts I got...... and one to sell
So are they sold?
 Post subject: fINAL ATTEMPT AT FITTING
PostPosted: Thu May 21, 2009 4:10 pm
Rover Cooper
With the advice from Mick last night, :oops: I attacked the clips with a pair of tin snips and drilled another hole and fitted them in the correct way, so I think they look a lot better now. :roll: :roll: :roll:
[/img]http://i171.photobucket.com/albums/u310/davo111_photos/Photo-0125_1.jpg[img]
[/img]http://i171.photobucket.com/albums/u310/davo111_photos/Photo-0126.jpg
PostPosted: Thu May 21, 2009 4:12 pm
Rover Cooper
Come on Mods, please fix the pics, dunno whats going on here... :cry: :cry: :cry: :cry: :cry: :cry: :cry:
PostPosted: Thu May 21, 2009 4:15 pm
Rover Cooper
PostPosted: Thu May 21, 2009 4:18 pm
Rover Cooper
and again.
Image :wink:
PostPosted: Thu May 21, 2009 4:20 pm
Is it just me or do your lights poke out a lot further than other mini's as well ?
PostPosted: Thu May 21, 2009 4:28 pm
That last photos reminds me of one that used to go around about why not to take photos of stuff to sell on ebay in your undies. :wink:
2008 Prado GXL
Users browsing this forum: No registered users and 126 guests
