It is currently Tue Jul 22, 2025 8:12 am
PostPosted: Thu May 28, 2009 9:14 pm
Hi AGAIN, not sure of the ID on me new mags.
Can anyone ID them, or are they just a cheap remake of someone elses?
mooo, I'm a pig!
PostPosted: Thu May 28, 2009 9:42 pm
High heel ninja
There a cheap knock of of the superlight. only narrow & usually fitted with a 145 tyre, usually bought from Tempe tyres or similar places
Doogie
PostPosted: Thu May 28, 2009 9:45 pm
Correct, they do have 145's on them. Dont really care if theyre a genuine rim or not. Should look good though.
Thanks Doogie.
mooo, I'm a pig!
PostPosted: Thu May 28, 2009 11:16 pm
the problem with them is the offset, they end up tucked underneath the guard and dont look right.
PostPosted: Fri May 29, 2009 8:54 am
.... which is very useful if you want to run 8.4" brakes without flares. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri May 29, 2009 4:59 pm
will using cooper stepped drums fix the problem and untuck them?
mooo, I'm a pig!
PostPosted: Fri May 29, 2009 8:27 pm
With the discs up front it may the only way to tell for sure is to wack them on and hope they don't rub on the inner arch at the rear.
PostPosted: Fri May 29, 2009 9:07 pm
Stepped drums give the same front track width as S discs do.
PostPosted: Fri May 29, 2009 10:11 pm
Ta guys, will just have to plop them on, and check it out.
mooo, I'm a pig!
