Im going to take a wild guess at the problem, but wont actually know until i pull the thing apart. But the drive gear is stuck to the crank, so cant move.
The idler gear has no bearing on it and slides into the needle rollers which are small, so there wont be much play there.
The gearbox still moves through all its gears, and the clutch still engages.
So, im guessing third motion shaft bearing, and roller bearing and casing.
When i bought a third motion shaft bearing last time it had a slightly smaller diamter.
Can someone help me with part numbers for the third motion shaft bearing single row. and the roller bearing on the end of the shaft.
_________________ Aussie Leyland, Aussie Factory, Aussie Mini S.
