It is currently Fri Jul 18, 2025 9:29 am
PostPosted: Tue Dec 11, 2007 4:04 pm
ausmini mod
ausmini mod
Door cards back on (one of them) the other being finished.
The MDF on the door card has been modified to allow the clamp to move.
Bascially, the MDF has been cut out, but the vinyl is still there... you cant tell from looking at it, but if you press the exact spot you can feel that there is no MDF behind it.
Pete.
PostPosted: Fri Sep 05, 2008 11:38 am
Just a slight delay since you've last posted, but how have you run the wires from the body to the doors? What does it look like in the door jam when the door is open?
-Alan
PostPosted: Fri Sep 05, 2008 12:05 pm
Would they work in a Moke?
I'm bored .... can you tell?
David L
PostPosted: Fri Sep 05, 2008 1:35 pm
Milatsmadmini
i think you need these ones ;)
stolen from the moke forum
thought that was a good one!
PostPosted: Fri Sep 05, 2008 5:31 pm
I am issing something here evidently; what's wrong with the Mr Bean foldover with a padlock ferchrissakes? :?:
PostPosted: Sat May 30, 2009 5:37 pm
Thanks Pristic. I just installed as per your instructions. From start to finish it took less than 1.5 hours. Works great.
1978 Mini S - "FAX"
PostPosted: Mon Jun 01, 2009 10:30 am
ausmini mod
ausmini mod
Good stuff!
Makes it much nicer doesnt it :D
PostPosted: Mon Jun 01, 2009 10:37 am
Thats the accepted locking method for roundnoses.
PostPosted: Mon Jun 01, 2009 11:22 am
Central locking in a round nose is do-able.
Very fiddly, but do-able.
Now, central locking, single piece glass and electric windows, that's a task! 8)
PostPosted: Mon Jun 01, 2009 12:27 pm
ausmini mod
ausmini mod
Done that with normal glass setup - not with single glass though... remote locking, hit the button and windows go up too ;)
Pete
PostPosted: Mon Jun 01, 2009 1:32 pm
Got any pics of the electric window setup?
I've already got the other two. 8)
 Post subject: No locks
PostPosted: Tue Sep 25, 2012 1:23 pm
Resurrecting this thread.... I'm about to do panel work on my doors and was looking for aftermarket locks (solex), but unfortunately they don't do specific ones for Leyland. Then thought I'd get universal locks and make modifications to the door as required. I really don't want to use the OEM locks - they are bloody terrible!
So, Instead of all that maybe I should just go with a keyless entry system. No alarm. Can anyone suggest some good, reliable, name brand keyless systems? And should I have no locks and patch the hole in the door while I'm doing the panel work? Or is it advisable to still have a (new) barrel in case??
Answer the Question....
BUT always Question the Answer
