It is currently Fri Jul 18, 2025 10:27 pm
PostPosted: Tue Mar 01, 2005 10:21 pm
I would get the box done first :idea: It's then out of the way and you can fidlle with the rest......
I't realy depends on what you won't...Rull race or realiable...I realy can't give you a cost but...if you want it realibale make sure the box is done first.. :!:
The build up from thier
If you wont to spend the money...Balance and ighten the crank and flywheel with the backing Plate..if the Bores are good just re ring them..this is up to you'r Mac...get a nice Cam,..... :idea: and do some nice head work.
What are you thicking for a carb..stay with a SU or something else;....Del/Web/Turbo/Sup :?:
Price wise it realy depends on what you want and what you require from it :arrow:
PostPosted: Tue Mar 01, 2005 10:27 pm
i have a fair bit o 1275 stuff if u are interested pm me. but the more u fix the less will break. so fair i have only broken things that i should have replaced in the first place but didn't have the cash. take your time with the build. a make it a quick engine first cause u will be kicking your self later down the line when u want more power.
PostPosted: Tue Mar 01, 2005 10:33 pm
ill go raid steve for you 2morro,see if he has a good remote gearbox,ill bring it home and rebuild it ready for you,we will put a centural oil pick up in,so you can keep up thru the hills,willie needs one now,i gotta de stewies next month...
let us no
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Tue Mar 01, 2005 10:35 pm
Try here if that doesnt work out.
I can vouch for their good work 8)
PostPosted: Tue Mar 01, 2005 10:39 pm
:roll:
they did a great rebuild on your dizzy eh willie,and set your float bown a butie.....
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Tue Mar 01, 2005 10:42 pm
Yep theyre good. :)
PostPosted: Tue Mar 01, 2005 10:45 pm
crack,snackle pop,or somthing like that
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Tue Mar 01, 2005 10:50 pm
OKay as per above...and add and add an additional 1/2 just in casee....thier is always something that need's replacing :!:
PostPosted: Tue Mar 01, 2005 10:52 pm
dobt build it for a mild revving 1310 and go out on the street and try pull crazy rev's out of it,coz it will go bang,and i dont wanna pull your motor out half a hour arfter i just put it in :wink:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
 Post subject: how much?
PostPosted: Wed Mar 02, 2005 12:17 pm
so andrew if you can rebuild one for me how much and when can i get it put in :D :D :?: its up to you though if you dont want to it dont matter but if ya can that would be great :D
PostPosted: Wed Mar 02, 2005 12:39 pm
ill do the box and diff,and stick the motor in for ya,but your better off letting someone with more no-how do your motor.
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
