It is currently Mon Jul 28, 2025 9:02 pm
PostPosted: Thu Jun 11, 2009 10:13 pm
can you fit one with engine in car from underneath on hoist?
if it can be done what else should you be replacing.
what time frame we looking at up on the hoist.
i bet this has been asked before :lol:
just curious about it.
PostPosted: Thu Jun 11, 2009 10:16 pm
High heel ninja
You don't need a hoist, work down in the engine bay, about 3hours it can be done.
Doogie
PostPosted: Thu Jun 11, 2009 10:28 pm
ok, cool thanks doogie.
would you Recommend replacing anything else while at it?
PostPosted: Thu Jun 11, 2009 10:42 pm
Clutch release bearing.
PostPosted: Thu Jun 11, 2009 10:50 pm
And when would these need to be replaced? I not sure of the condition of mine,
Can it lead to bigger damage if say the clutch plate or the release bearing fails?
PostPosted: Thu Jun 11, 2009 11:31 pm
I heard The People's Republic do a good one. :)
PostPosted: Fri Jun 12, 2009 10:09 am
Not tried a PRC one, but the Japs do a bad one. :x
Timken 3W5-8 flat one is the best, all the later ones are a poor substitute.
PostPosted: Fri Jun 12, 2009 11:06 am
ahhhh ive done this several times in the last couple of weeks.
disconnect battery
undo the engine mounts at top on both sides.
remove starter motor, remove coil, remove earth strap.
undo engine mount underneath clucth housing
jack car up, put blocks underneath the gearbox
lower car down, make sure your fan blade dont hit your radiator or you got to many blocks under the gearbox.
then your read to take the housing off from above, UNLESS you have that one bolt in that will hit the subframe, always replace with a short bolt or leave it out when you put it back together
you can get the flywheel off inside the car too given you have a puller for it.
reverse to put it back together.
DAMN SHUDDERS :roll:
PostPosted: Fri Jun 12, 2009 5:45 pm
NAV-MAN
I have a clutch puller that will work in the car if you need to borrow one.
If you have all the bits and pieces you can do it in my garage on a weekend and I'll help you if you like. I'm in Murrumba Downs.
PostPosted: Tue Jun 16, 2009 11:35 am
Thanks Nav.legend.. nice gesture indeed :)
Richard King is going to come do it at my place with me & get the car all fired up.
he did not want much to do it in the car so i'm going to go with that. but im not far from you really at all.
can anyone point towards a good Clutch kit to buy?
mines a Verto 1994 converted to carby engine.
im not sure what Clutch i need. there seems to be a few on mini spares.
im about to do a big order so ill grab it from there also.
http://www.minispares.com/Product.aspx? ... VERTO%20...
http://www.minispares.com/Product.aspx? ... EEL%20KI...
can some one list what i should be buying?
ill replace the lot while down there.
confused.
PostPosted: Tue Jun 16, 2009 11:38 am
Gah... wrong super power.. :P
PostPosted: Tue Jun 16, 2009 11:56 am
Nick, you can replace worn verto clutch with std verto replacement parts,,,, or you can swap the whole lot over to "pre-Verto",,,(Hmmm sounds kinky "Preverto") :-) But the "Whole" lot would need swapping out,,,flywheel, backplate, clutch plate, throw-out bearing, carrier, arm, etc etc etc
It`s all your choice,,, but the pre-verto (early) assembly is just lighter in weight if you were keen for more accelleration,,, that`s all
& would definately replace the oil seal & the throw-out bearing either way
Users browsing this forum: No registered users and 66 guests
