It is currently Tue Jul 29, 2025 8:53 pm
 Post subject: hard brakes
PostPosted: Mon Jun 15, 2009 9:12 pm
HI guys, I fitted new pads and rotors and had the brake fluid changed. I took it over mt glorious with 2 screaming women and because they demanded i brake for each corner, they over heated. now a few months later they dont have any bite? Can i take the pads off and hit them with an wire wheel? whould that remove any glazing or should I through them away and start over again??? There is no bad feeling through the brake pedal ( ie warped rotar) just it slows gradually and a hard pedal.
PostPosted: Mon Jun 15, 2009 9:16 pm
what pads are they? sometimes if you run track day pads they dont get hot enough to work well in normal road conditions
Potato
PostPosted: Mon Jun 15, 2009 9:27 pm
Wire brush won't deglaze them properly.
I'd hold them carefully on the side of a big grinding wheel. :wink:
PostPosted: Mon Jun 15, 2009 9:31 pm
On the races cars we had a scientific way of doing de-glazing the brake pads, we would rub them on concrete. :lol:
PostPosted: Mon Jun 15, 2009 9:43 pm
cant remember but they could be race brakes, cause i went for high performance pads.
PostPosted: Mon Jun 15, 2009 10:33 pm
We just run them over the surface grinder at work :D
PostPosted: Mon Jun 15, 2009 11:30 pm
thanks guys going to a go at them this weekend!
PostPosted: Tue Jun 16, 2009 7:11 am
Just be careful of the dust Brett , I know they aren't meant to have asbestos in them anymore but treat it as if they do ...
