Wanted something to practice a bit of electroplating so thought the cover strip on the Starter Motor was a good candidate
I had wired brushed about a month ago but surface rust was showing up again.
Gave it another go on the wire wheel then cleaned it with Prepsol. - left the inside to compare.
This is the Setup with a Lab Bench Supply
Current was eventually set at 500mA for 1 hour
The finished artical - not as even as I hoped but good enough - a few 'golden' streaks and some dull patches otherwise it appears to be evenly coated.
And in place on the Starter Motor.
David L
